Old 05-06-2020, 11:59 PM   #1
bdtutton
Default Lighting for speedometer and gas gauge
Is there a way to backlight the speedometer and/or gas gauge? When I turn on the dash light it is distracting because it reflects off the windows at night and is even worse if it is raining. Does anyone have any good ideas that would make these gauges more useful at night?
bdtutton is offline   Reply With Quote
Old 05-07-2020, 12:55 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Lighting for speedometer and gas gauge
It would be kinda hard to back light the gas gauge as it is screwed into the tank. You might be able to install a bulb behind the face above the speed indicator so it could be illuminated. For checking the gas, maybe a flashlight would work to check. Are you saying in the rain the gauges are fogging up?
Old 05-07-2020, 01:58 AM   #3
dumb person
dumb person's Avatar
i turned the light off when i didn't need it. Put red cellophane over the bulb helped a bit. Not backlit but not as distracting.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-07-2020, 03:47 AM   #4
old31
I just turn the light on when I need it.
old31 is offline   Reply With Quote
Old 05-07-2020, 06:29 AM   #5
Steves46
Steves46's Avatar
If you are running 6 volts, maybe a 12v dash light bulb will reduce brightness and strong reflection.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 05-07-2020, 08:00 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Do you have the cover over the bulb--- I drive a lot at night, don't notice any dash light reflection on other places, mine is a 31 with light up behind dash rail, all original parts
Old 05-07-2020, 08:31 AM   #7
daren007
You could drop a flashlight in the gas tank although I wouldn’t recommend it.
daren007 is offline   Reply With Quote
Old 05-07-2020, 08:55 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Is the Instrument Panel chrome plated, -or Butler finished? Also, do you have the correct 3cp bulb??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-07-2020, 07:39 PM   #9
Jim/GA
Jim/GA's Avatar
This is what I do. Works great!
You will think it is too dim at first, but once your eyes adjust to it, you can see the instruments just fine.
Jim Cannon
"Have a Model A day!"
Old 05-07-2020, 08:49 PM   #10
Doug Linden
Doug Linden's Avatar
I agree with Jim, have been doing this for years. A #67 12 volt bulb works just fine.
Doug Linden is offline   Reply With Quote
Old 05-07-2020, 09:54 PM   #11
briphaeton
I would like to get a LED bulb so it would get so hot.
briphaeton is offline   Reply With Quote
Old 05-08-2020, 09:02 AM   #12
Badpuppy
LED bulbs come in bright, brighter and nuclear. Use the #67, it won't get very hot at 6V.
No bulb will get hot unless you leave it on all the time. Turn it back off after you check your gauges.
Old 05-08-2020, 09:30 AM   #13
Jim/GA
Jim/GA's Avatar
If you use a #67 12 volt, 3 cp tail light bulb in the instrument light on a 6 volt car, it will not get hot. You can leave it on all the time at night and not burn your fingers turning it off. It gives a nice glow on the instruments.
If you have converted your car to 12 volts (), then you use a 24 volt 3 cp tail light bulb in there, bulb number 1251, to get the same soft glow. They are kind of hard to find. Try ordering from your local NAPA, or order online.
Jim Cannon
Old 05-08-2020, 03:12 PM   #14
mngreen
mngreen's Avatar
I am running 12V and I tried the 24V bulb you suggested some time ago. Total waste of time as that bulb barely made the filament even glow!
Instead, I replaced it with a 12V LED bulb which works great with no heat.
mngreen is offline   Reply With Quote
Old 05-08-2020, 03:20 PM   #15
The Master Cylinder
The Master Cylinder's Avatar
I guess it may depend on the style of dash light, the '28-29 or the '30-31. I use a 'soft warm' LED in my '30 and it works fine. I imagine if you didn't have the cover on it, it may be a different story. As mngreen said, no heat.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-08-2020, 04:49 PM   #16
Jim/GA
Jim/GA's Avatar
Sorry to hear that. It works well in my car.
I will admit, it takes a few minutes to get used to the dim light on the instruments.
Maybe your electrical connection or ground was not really good. LEDs take much less current so are less impacted by a bad connection.
Jim Cannon
Old 05-08-2020, 05:07 PM   #17
mngreen
mngreen's Avatar
No bad ground or bad connection---the incandescent 12V bulb that I originally had in there burned bright and HOT (for the last 40 years).
12V LED bulb now burns bright and COOL!
24V bulb
Mike Green
Old 05-08-2020, 08:50 PM   #18
JoeCB
JoeCB's Avatar
My IP light also has a shroud covering the bulb with only a opening facing down... no light upward to reflect off of the windshield.
Joe B
JoeCB is offline   Reply With Quote
Old 05-09-2020, 10:07 PM   #19
dumb person
Haha. Reminds me of the first time i went to turn off the dash light & realized the cover was very hot. I think the cover fell off which was really annoying..
Anyway. If people find LEDs are too bright, i find colouring them in with a 'sharpy' (felt tip pen in my country) reduces the brightness quite well. Add extra layers of ink if you need it duller.
Also good idea.
Old 05-10-2020, 12:05 AM   #20
CarlG
CarlG's Avatar
Which LED bulb did you use?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
