Old 06-21-2021, 09:23 AM   #1
kursed30
kursed30's Avatar
Default New Carb
If I need to replace my carb, would you go with a Zenith or Tillotson?
kursed30 is offline   Reply With Quote
Old 06-21-2021, 09:34 AM   #2
alexiskai
alexiskai's Avatar
Default Re: New Carb
Marvel carbs tend to be more trouble-free, if you're not concerned about strict period accuracy (the Marvels were introduced in '46).
Old 06-21-2021, 10:03 AM   #3
dpson
dpson's Avatar
I've tried a number of different carbs, including rebuilt Zeniths, and found the Marvel-Schebler, aka Allstate, Marvel and other names, worked best for me.
dpson is offline   Reply With Quote
Old 06-21-2021, 10:09 AM   #4
johnbuckley
johnbuckley's Avatar
The question was Zenith or Tillotson..... Zenith for me ; the Tillotson can be smoother acceleration but more tricky to fix if warped/corroded
johnbuckley is online now   Reply With Quote
Old 06-21-2021, 10:29 AM   #5
nkaminar
nkaminar's Avatar
For a real boost in performance a two barrel Weber downdraft is a good choice, along with the aluminum intake manifold that comes with it.
Old 06-21-2021, 10:35 AM   #6
Anteek29
Anteek29's Avatar
My A runs smoother on a Tilly.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-21-2021, 11:02 AM   #7
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I run and like the Marvel carb. My Zenith has become my under the seat backup carb. The Marvel is completely rebuilt and cost $200 with free shipping.
Here is where to get one:
MARVEL SCHEMBLER CARBERATOR
JR BULLOCK
976 COUNTRY ROAD 2310
TEXARKANA, TX 75503
903-748-8299
[email protected]
Dick M is offline   Reply With Quote
Old 06-21-2021, 11:19 AM   #8
Bob Johnson
Bob Johnson's Avatar
I think it is hard for most people to say which is better. They can tell you which one works better for them. However you do not know what they are comparing. Are they comparing carburetors that are like new? Are they comparing one that is new (or correctly restored) with an old one that is worn? I would recommend that you use a carburetor that is properly setup.
Bob
Bob Johnson is offline   Reply With Quote
Old 06-21-2021, 11:23 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
You can have your pick of rebuilt Zenith, Tillotsen or Marvel at Jim's Carbs https://jmacarbs.com
I would not reccommend a NEW carb (which the heading states) from the vendors tho. I have had some issues with them.
Old 06-21-2021, 11:26 AM   #10
alexiskai
alexiskai's Avatar
Yeah, but the OP is new and I figure he's looking at a catalog and thinking those are his only options.
Old 06-21-2021, 12:13 PM   #11
Rob Doe
JR BULLOCK
TEXARKANA, TX 75503
903-748-8299
[email protected]
Dick, does the Marvel mate with the throttle, choke, and GAV without customization?
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 06-21-2021, 12:18 PM   #12
johnbuckley
Originally Posted by johnbuckley ...The question was Zenith or Tillotson
Sorry, Couldn't help pointing that out ....a throw back from my formative years when teacher told us to always " Answer the question , not answer what you think the question ought to be "
Old 06-21-2021, 12:43 PM   #13
alexiskai
alexiskai's Avatar
If you get it from Jim Bullock, it does. Fuel line too. Five stars for jmacarbs.com.
Old 06-21-2021, 01:22 PM   #14
Y-Blockhead
Does the Marvel mate with the throttle, choke, and GAV without customization?
Just like it was made for it...
Old 06-21-2021, 02:43 PM   #15
Brentwood Bob
Trendy.
And probably expensive, and eventually you may want to learn how to trouble shoot whichever carb you decide to use.
There are a lot of decent zenith cores. I have had good results using OEM internals.
Brentwood Bob is offline   Reply With Quote
Old 06-21-2021, 03:06 PM   #16
Jim M
Jim M's Avatar
I have a zenith that works great. The key to performance is J R Bullock in Texarkana! Nicest person you will ever talk to. I sent mine to him and when it came back just bolted it on and have NEVER touched or adjusted it. Car starts, idles, and runs like a champ. Not only does he do a great job but nicest guy to talk to. CAN'T go wrong!!
Jim M is offline   Reply With Quote
Old 06-21-2021, 04:39 PM   #17
old31
To answer the initial question, I would go with a tilly over Zenith.
If I could choose between all 3, I would go with Marvel.
old31 is offline   Reply With Quote
Old 06-21-2021, 04:50 PM   #18
kursed30
kursed30's Avatar
I noticed that JR guy rebuilds also. I have two Zeniths and two Tillys. Thinking maybe have one of the four rebuilt and sell 3 cores to him for a new one. That way i have a spare.
Old 06-21-2021, 04:58 PM   #19
Gene F
Gene F's Avatar
A B carb for me, but I have the Brumfield head, the big valves, and the IB-330 cam. I used to run the Zenith, which worked just fine.
Old 06-21-2021, 04:59 PM   #20
Gene F
Gene F's Avatar
Sometime I'd like to go for a spin in an A with the downdraft setup.
