03-26-2018, 10:45 PM | #1 |
Wheel spacers needed
My 750X16 tires on widened rims rub on the body of my Tudor when cornering. I can see I have room to move the wheels outward at least an inch. My problem is trying to find wheel spacers with the two different mounting surface levels. Anybody know where to get them?
TIA, Chris
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
03-27-2018, 08:13 AM | #2 |
Re: Wheel spacers needed
I think Rally America has what you are looking for 5x 5 x 1/2 I think 1 1/4 thick
03-27-2018, 09:19 AM | #3 |
Speedway Motors
No restorable Model A's were harmed in the building of this truck! |
03-27-2018, 12:47 PM | #4 |
www.whidbeymodelaclub.com |
03-27-2018, 02:26 PM | #5 |
I don't think what you need is available but not a big deal to modify the available early Ford 5.5" wheel to newer 5.5" hub spacers that are available. A relief needs to be machined into the inner face of the spacer so it will properly fit the Model A hub. I would give Jimmy at Rally America a call - very knowledgeable. Their adapter/spacers are steel I believe whereas Speedway's are aluminum.
03-27-2018, 05:11 PM | #6 |
You say that the wheels rub when you corner. I assume from that they don't normally. Maybe a Panhard bar is what you need. There was a thread about them quite recently.
03-27-2018, 05:24 PM | #7 |
Thank you all for your ideas. :-)
