Old 08-22-2021, 07:39 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Coil Question/Not starting
We have a 30' Roadster high point car in the shop that won't start. Within a few seconds of turning the engine to start, the coil gets so hot it can not be touched.
I have 6volts at the end of the ignition cable, and 6 volts at the points. But no spark at the plugs.
My thoughts are that the condenser is bad, and probably the coil because of severe overheating.
Anyone have any thoughts??
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 08-22-2021, 08:04 PM   #2
Conaway2
Conaway2's Avatar
Default Re: Coil Question/Not starting
Sounds like there is an issue with the coil. I would swap it with a known good one.
Good luck - Jim
Conaway2 is offline   Reply With Quote
Old 08-23-2021, 01:55 AM   #3
Synchro909
Synchro909's Avatar
Put an Ohm meter across the terminals and let us know the result.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-23-2021, 07:40 AM   #4
mgambuzza
mgambuzza's Avatar
Great advice as that's how I further determined mine had failed the other day.
mgambuzza is offline   Reply With Quote
