Old 09-16-2021, 06:37 PM   #21
Step-down
Step-down's Avatar
Default Re: got a hole in my water jacket
Please don’t laugh but try the old plumbers trick . Stuff lots of white bread in the hole so it can hold the water back then JB weld
Can’t hurt
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 09-20-2021, 12:45 PM   #22
Ron_r1959
Ron_r1959's Avatar
Can’t hurt
That works well on water pipes for sure! Done it many times my self. Don't try it with silver rod though..... way to much heat Lol it turned to a solid plug in the line. Its a great trick on soft soldier though! worth a shot I would think.
Ron_r1959 is offline   Reply With Quote
Old 09-21-2021, 11:04 AM   #23
erguitar
Originally Posted by 51 MERC-CT View Post
Depending on where it is, an option would be to install a suitable size pipe plug along with JB weld.
Completely agree with this . I have fixed leaks by drilling/tapping the area,. Installing a brass plug with jb weld on the threads, grinding it flat to the block and peening it. Cant see it when you're done with a little paint and seals it right up.
Don't know if you have access to do all that with the engine in the car or perhaps you've solved it by now (?).
Anyway, good luck.
erguitar is offline   Reply With Quote
