10-08-2021, 10:55 AM | #21 |
Re: Help - Front End is Off Center
It looks like the spindle arm nuts do not have cotter pins in them either. You need to check that every place there should be a cotter pin has one.
10-08-2021, 11:07 AM | #22 |
Thanks. Those are temporary nuts until new ones arrive. Car is not moving - steering column is out for rebuild.
Bob |
10-08-2021, 11:33 AM | #23 |
I still think the shock arm
10-08-2021, 12:02 PM | #24 |
Here are photos of the left shock
10-08-2021, 03:55 PM | #25 |
Maybe the dog bone ????
10-08-2021, 04:13 PM | #26 |
10-08-2021, 04:15 PM | #27 |
10-08-2021, 05:28 PM | #28 |
My last guess.....someone jacked the rails apart to get the front X in ???? Run a string under the car from front X back
10-10-2021, 12:30 PM | #29 |
Is it possible that the front axle is off center? When I set a plumb bob down from the center of the crankshaft to the axle, the mark is not on the center of the axle. The mark is, depending on how I measure, about .5 - .75" from the center of the axle. If that is the case, how do I recenter the axle to the vehicle?
Thanks |
10-10-2021, 01:12 PM | #30 |
Did you check the spring center bolt hole in the crossmember to see if it was centered between the frame rails?
Bill |
10-10-2021, 02:01 PM | #31 |
Spring hole is centered. New bolt coming Tuesday
10-10-2021, 09:32 PM | #32 |
Bad frame
10-11-2021, 09:16 PM | #33 |
Different actuating shafts? There two different ones with different arms.
10-11-2021, 09:28 PM | #34 |
Look at picture with tape measure on driver's side. The frame has deep gouges(damage) . The front X is floating on that side , as well
