Old 08-02-2021, 07:49 PM   #1
Conaway2
Conaway2's Avatar
Default Rear Wheel Bearing Question
Does anyone know where I can find the factory spec for the OD of the wheel bearing surface in the rear axle housing ?
I’m trying to decide whether or not I need to have a new bearing surface pressed on, as the original surface doesn’t look very worn. I’m measuring about 2.620” on each side.
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 08-02-2021, 08:16 PM   #2
Conaway2
Conaway2's Avatar
Default Re: Rear Wheel Bearing Question
Thanks - Jim
Never mind - just found the spec on Bratton’s site (2.061 to 2.063”). My measurement is actually 2.062”, so I don’t need to replace the bearing surfaces at this point.
Jim
Old 08-02-2021, 09:11 PM   #3
chrs1961815
chrs1961815's Avatar
Glad you found your answer. I have found that it is very hard to mess up rear wheel bearings on a Model A so long as they are kept greased. Most everybody just reuses them.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
