10-12-2021, 11:28 AM | #1 |
which bearing
I'm putting 1940 ford rear backing plates and drums / hubs on my 31 model a , what hub bearing do I use ?
Vern |
10-12-2021, 11:54 AM | #2 |
Re: which bearing
To match hubs
10-12-2021, 03:15 PM | #3 |
Re: which bearing
Not sure what your asking me ? Can I use the same bearing as was in my model a hub , or do I need the 40 ford bearing , or are they the same ?
10-12-2021, 03:23 PM | #4 |
Re: which bearing
I would get the correct bearing for a 40 ford hub.
10-12-2021, 06:56 PM | #5 |
Re: which bearing
V8 bearing up to 1948 is is the one to use. Model A bearing will not fit the 40 Ford Hub.
10-12-2021, 07:33 PM | #6 |
Re: which bearing
Vern |
10-12-2021, 08:03 PM | #7 |
Re: which bearing
You will need Ford part # 68-1225 or equivalent bearing, used in rear hubs from late 1936 through 1948.
10-12-2021, 08:22 PM | #8 |
Re: which bearing
URSUS , thanks
10-13-2021, 01:09 PM | #9 |
Re: which bearing
Avoid reproduction bearings as their quality is very questionable. Even used Genuine Ford
1940 Ford bearings would be better. |
10-13-2021, 07:15 PM | #10 |
Re: which bearing
19Fordy , Who sells the good ones ?
