Old 09-30-2021, 03:17 PM   #1
40-A Twins
40-A Twins's Avatar
Default Crank case breather spits up oil
The oil breather was spitting up drops of oil at high idle, which land on the coolant tube and side of the motor. Never noticed this before. Now I know why the motor is always coated in oil in places I would not expect it to leak.
40-A Twins is offline   Reply With Quote
Old 09-30-2021, 03:28 PM   #2
Werner
Werner's Avatar
Default Re: Crank case breather spits up oil
This can be due to the fact that blow-by gases between the piston and cylinder are increased due to wear.
Or maybe motor oil that has become considerably too thin?
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-30-2021, 05:17 PM   #3
mercman from oz
mercman from oz's Avatar
40-A Twins and his Oil Breather that spits oil when idling.
Old 09-30-2021, 05:17 PM   #4
old ugly
old ugly's Avatar
you may already know this.?
make sure the tube has the fins inside it and that it is not just a straight through tube.
and
make sure it is not partially plugged with sludge and obstructing crankcase pleasure from freely escaping.
old ugly is offline   Reply With Quote
Old 09-30-2021, 05:30 PM   #5
nkaminar
nkaminar's Avatar
Many cars are fitted with an aftermarket tube that leads to under the car. This allows any oil that bypasses the fins inside to go out on the road and not on the engine. I don't see the tube advertised on Snyders so maybe it is a swap meet item.
Old 09-30-2021, 07:44 PM   #6
Big hammer
Make sure the cap isn't pushed down to far and the cap is free of foreign objects! Some people put socks over the cap and tube.
get a bigger hammer tap done
Old 09-30-2021, 07:51 PM   #7
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Is the cap on too tight? Do you have too much oil? Do you have anything in the tube like steel wool that is not allowing the crank case to breathe?
Ivan in southeast va. is offline   Reply With Quote
Old 09-30-2021, 07:56 PM   #8
And...as Big hammer said, put a sock on it! Change as needed.
Old 10-01-2021, 12:09 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
How high do you keep the oil level
If you look in the service bulletins there were changes in the baffles to reduce oil escaping--- look to see what version you have
I overfilled my smiths compresser (oil level on the "f" instead of under it), I watched it spray oil till the level got below the F
Old 10-01-2021, 12:53 AM   #10
jg61hawk
https://www.fordbarn.com/forum/showthread.php?t=222758
Look this thread over from top to bottom
jg61hawk is offline   Reply With Quote
Old 10-01-2021, 08:07 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
Index the breather pipe so its baffles stop the oil:
Bob Bidonde
Old 10-01-2021, 09:41 AM   #12
Ruth
To add to what Kurt wrote, Ford redesigned the breather pipe a few times over the years to 'cure' the problem of oil coming out of the breather tube. see the Service Bulletins pages 358 & 454.
Ruth
Old 10-01-2021, 10:30 PM   #13
40-A Twins
40-A Twins's Avatar
This a post Model A production motor (1936 diamond block) so it should have been equipped with the redesigned breather. I will check the orientation of baffles.
Old 10-02-2021, 01:48 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
It may have BEEN equipped with it, but 85 years later???
Old 10-03-2021, 02:08 PM   #15
fundytides
fundytides's Avatar
As it was a replacement block, all of the "accessories" off the original block may have been used.
fundytides is offline   Reply With Quote
Old 10-03-2021, 05:10 PM   #16
Gene F
Gene F's Avatar
I have heard people say take the tube and cap out, and get one for a Model B. I have no idea if that works even a little bit.
Gene F is offline   Reply With Quote
