Old 09-10-2021, 06:49 PM   #1
Ford coupe
Angry Steering wheel play
When driving my 55 i have about 3 inches of play either way thus making it difficult to steer...Can i take a bit of this out with the set screw on top of the steering box or??..Thanks in advance..
Ford coupe is offline   Reply With Quote
Old 09-10-2021, 07:09 PM   #2
Shoovel
Shoovel's Avatar
Default Re: Steering wheel play
Sounds like too much play to take up with a steering box adjustment. I would be checking the front end components. With the weight of the car on the front end, have a helper move the steering wheel back and forth slowly to take up the play and you watch all steering components.
Shoovel is offline   Reply With Quote
Old 09-10-2021, 07:41 PM   #3
terry
When i had a 48 ford pickup, I had the same problem. I was able to remove a shim from the steering box and it worked for me...no more play. Terry
terry is offline   Reply With Quote
Old 09-11-2021, 07:28 PM   #4
joe 1950
joe 1950's Avatar
i agree with shovel need to ck the tie rod end , idler arm,pitman arm first
joe 1950 is offline   Reply With Quote
Old 09-11-2021, 07:47 PM   #5
flathead4rd
flathead4rd's Avatar
The locking screw on top of the steering box does not take play out of the steering wheel. You have to loosen the four small bolts on the front of the box and rotate the plate clockwise. Do not make big adjustments. Move it no more than a sixteenth 1/16" of and inch at a time. Check play after each minute adjustment.
flathead4rd is offline   Reply With Quote
