Old 09-28-2019, 09:41 PM   #1
Shortdog
Shortdog's Avatar
Default Radiator replacement
Have anyone replaced their radiator with the heavy-duty one. If you have, did it make a difference with the motor overheating?
1931 Model A Coupe
Wisdom is not a product of schooling, but of a lifelong attempt to acquire it.
Shortdog is offline   Reply With Quote
Old 09-29-2019, 06:56 AM   #2
kenparker
kenparker's Avatar
Default Re: Radiator replacement
I have bought Snyder's "heavy Duty" radiator twice. each time it solved the overheating problem. In each case I was replacing a worn out original radiator.
kenparker is offline   Reply With Quote
Old 09-29-2019, 07:01 AM   #3
ahirt
I bought a Bratton's heavy duty radiator for my 28. In Florida the weather is always hot. The new radiator fit great and solved the running hot problem. In fact, it may actually be running a bit cold especially on days that don't go above 80 outside.
ahirt is offline   Reply With Quote
Old 09-29-2019, 07:51 AM   #4
rfitzpatrick
Brassworks -- best money I've ever spent on the PicUp
rfitzpatrick is offline   Reply With Quote
Old 09-29-2019, 08:10 AM   #5
Purdy Swoft
Purdy Swoft's Avatar
When I buy a radiator for one of my model A's I buy the eight fins per inch version . more fins per inch cools better . I usually want every advantage that I can get .
Old 09-29-2019, 01:16 PM   #6
Shortdog
Shortdog's Avatar
What about the one that is ten fins per inch. How much better would it be over the eight?
1931 Model A Coupe
Old 09-29-2019, 02:20 PM   #7
kenparker
kenparker's Avatar
one should look at combination of number of tubes AND fins per inch. Each contact of fin to tube is a point of heat dissapation.
Old 09-29-2019, 02:22 PM   #8
Purdy Swoft
The 10 fin radiator should be even better . I don't think that the vendors that I dealt with had the 10 fin radiators at the time that I bought mine or I would has have got the ten fin .
Model A radiators are very expensive now days . The new radiator that I bought for my 31 coupe in 1990 was only $180.00 . This is a three row radiator with 6 fins per inch and has never over heated .
Old 09-29-2019, 02:52 PM   #9
Synchro909
Synchro909's Avatar
A new Brassworks HD radiator made no difference to my car. Still overheats in high ambient temps, just like the old one. That is a stack of cash I won't get back!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-29-2019, 06:01 PM   #10
1931 flamingo
1931 flamingo's Avatar
I would think that you've got other mechanical issues then, i.e." timing, plugged block, w/pump. Most that replace with Brassworks or other quality cores have trouble "warming" them up. FWIW
Paul in CT
