06-01-2016, 04:48 PM | #1 |
Socket size for connecting rod cap bolts on A Engine
Working on my old Model A block today and got the oil pan removed. Lots of sludge oil... It seems the connecting rod cap nuts is 21/32... Bought a 21/31 12 point socket and it doesn't seem to grab like it should and wants to round off the edges of the nut I tested it on... Looks like I'm gonna have to order a 21/32 6 point socket...Should have known better...
The 1 3/8 socket I bought to remove the crankshaft pully nut doesn't fit either... too tight to go on.. I think its rust build up on the nut... Any advice is appreciated. Thanks Last edited by mjr67; 06-01-2016 at 05:00 PM. |
06-01-2016, 05:38 PM | #2 |
Re: Socket size for connecting rod cap bolts on A Engine
I have seen rod nuts in 5/8 21/32 and 11/16, so check them all.
06-01-2016, 05:43 PM | #3 |
The "rebuilt" engine that was in my PU when I bought it had a mix of sizes. As Mr. Thibodeau says: check them all.
06-01-2016, 05:58 PM | #4 |
if you mean the square nuts , use an 8 sided 9/16
V4f |
06-01-2016, 06:12 PM | #5 |
The 17MM is a perfect fit. Been using one for years.
06-01-2016, 07:43 PM | #6 |
06-01-2016, 07:55 PM | #7 |
06-01-2016, 08:49 PM | #8 |
Original nuts took a 21/32 socket.
06-02-2016, 09:55 AM | #9 |
17mm = 0.6692913 inches
21/32 = 0.65625 inches 17 mm is oversize
06-02-2016, 12:34 PM | #10 |
Ooooo, by .013". Make sure you use a 6 sided socket...
