Old 04-05-2020, 07:57 PM   #1
wright-47
Default 36 Transmition bearings
Just wondering if anyone has used a sealed bearing for the input shaft and not used the wick seal? I would think the oil drain hole would have to be sealed. Stay safe and healthy.
wright-47 is offline   Reply With Quote
Old 04-05-2020, 08:56 PM   #2
svm99
Default Re: 36 Transmition bearings
Use a ‘37 and later front bearing retainer with a seal. Seals are readily available. Use a shielded bearing.
svm99 is offline   Reply With Quote
