Old 09-21-2018, 10:29 AM   #1
Ricosan
Ricosan's Avatar
Default New carb installed
Hey guys,
I finally got my English Stromberg 97 carburetor and installed it yesterday. I took it out for a test drive and it sounded like it was missing on 2 or 3 cylinders.
It was running without this problem with my old carburetor so I pulled the plugs. They were black, covered in carbon. I had less than 200 miles on this set of plugs. I replaced the plugs and the engine is running good now.
Is this sound like a fuel delivery problem or an electrical problem?
Richard
Ricosan is offline   Reply With Quote
Old 09-21-2018, 11:08 AM   #2
scicala
scicala's Avatar
Default Re: New carb installed
If it runs good now, I would guess you had a temporary flooding problem that went away. Possibly from some contamination that got caught in the fuel valve and seat, that cleared itself out, but originally caused a very high fuel level. Just a guess.
Sal
scicala is offline   Reply With Quote
Old 09-21-2018, 04:29 PM   #3
Don
Don's Avatar
The carb can cause a flooding condition on certain plugs,If you look on the back side of a intake!ther are runners that feed certain cyl....2&3 cyl come from one of these runners,had this problem on my 36 with 8ba,was ready to pull heads to check for stuck valves,,plugs were fouled on 2&3 ....made several checks then removed carb and desembled and cleaned including the emulsion tubes!didnt see anything but when I started up problem was gone!!!!
DON P
Don is offline   Reply With Quote
