Old 07-17-2018, 02:00 AM   #1
ford nut
ford nut's Avatar
Default 36' grill question. . . .
i'm working on my 36 5 window coupe's grill and I've got a question about the lower inside piece, I don't know what to call but it's kind of a shroud / gravel guard / stiffener thing with some vertical louvers stamped into it and a spot for the crank to pass through. I thought it was welded in but while moving the grill around cleaning it up, the inner piece moved. I don't see any spot welds anywhere, can this inner piece be removed? it would sure make it easier to tap a little dent out of the center bar. how do I get this out without bending it? thanks, kurt
ford nut is offline   Reply With Quote
Old 07-17-2018, 03:56 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 36' grill question. . . .
Its called the apron assy in the Green Bible.I have heard it referred to a grille baffle .Yes it removes when you pull the grille out.
deuce lover is offline   Reply With Quote
Old 07-17-2018, 07:34 AM   #3
Don Rogers
Don Rogers's Avatar
The inner piece called the radiator shell apron (68-8240) can be removed. See photos.
Don Rogers is offline   Reply With Quote
Old 07-17-2018, 04:33 PM   #4
ford nut
ford nut's Avatar
you guys are right, it came out. it was really bound in there, I had to really open the grill shell up to get it out. that a great picture of a un-bent one. mine doesn't look so good. time to start tapping on it. anybody else got a picture of good straight ones?
Old 07-17-2018, 06:09 PM   #5
ford nut
ford nut's Avatar
another question for anybody who knows these grills, is this crimped section near the crank hole factory? or do I need to work it out. here some pics of my bent grill shell apron. i'm sure happy that I can post pictures again too.
Old 07-17-2018, 06:47 PM   #6
V8ER
The crimped section of the center rib should be straight. The top edge of the grille apron should be straight.
V8ER is offline   Reply With Quote
Old 07-17-2018, 07:16 PM   #7
ford nut
ford nut's Avatar
how about pic three that shows bottom edge, mine has a curve to it. should that be straight too? it would get wider if straightened out, maybe a different factory?
Old 07-17-2018, 11:21 PM   #8
Voycey
Voycey's Avatar
Hi Apologies for jumping on this post but are these available anywhere as a repop.
Voycey is offline   Reply With Quote
Old 07-18-2018, 12:21 AM   #9
ford nut
ford nut's Avatar
I've never seen it as a re-pop.
Old 07-18-2018, 10:13 AM   #10
J Witt
J Witt's Avatar
Here's a photo of mine, taken when I last had the grille off. Just had it powder coated satin black. This photo may offer some help even though it doesn't show both edges.
BTW, I got a hardware kit from Roy Nacewicz ( http://fordscript.com/ ) that was a big help putting it all back together.
Good luck, getting all the holes lined up was a pain. I used several tapered punches to do that.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 07-18-2018, 11:56 AM   #11
cmbrucew
cmbrucew's Avatar
"I used several tapered punches to do that."
Plus a few small vise grips help a lot.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-18-2018, 01:02 PM   #12
johndee138
johndee138's Avatar
Is this piece really necessary?
johndee138 is offline   Reply With Quote
Old 07-18-2018, 02:06 PM   #13
DavidG
DavidG's Avatar
It adds reinforcement to the front fender attachment as well as serving as baffle to direct air flow to the radiator, so I'd say the answer is yes, it is necessary. The same goes for the comparable panel behind the bottom of a '35 grille.
Old 07-18-2018, 02:16 PM   #14
dkd35
Yes it needs to be put back. With out it air flow to the radiator is gone. It put air flow to the bottom of the radiator. Didnt put mine in overheated so put it back no proplems.
dkd35 is offline   Reply With Quote
Old 07-18-2018, 02:52 PM   #15
ford nut
ford nut's Avatar
thanks for the photo j witt. it helps to show how bent up mine is! I think it will be fine though.
