Old 03-21-2018, 03:38 PM   #1
wrndln
Default Acetylene verses propane
I was at my local welding store today to see if my acetylene regulator was leaking. The regulator appears to be OK after some testing. Anyway, I was talking to the fellow in the store and he told me propane could be used in place of acetylene to heat nuts and bolts to loosen them much cheaper than acetylene. He said an adapter (CGA-510 to CGA-200) to adapt the acetylene regulator to the propane tank was necessary to use propane. He was out of the brass adapters that run $11 to $20 on eBay. Has anyone used propane in place of acetylene for their torch and if so, what were the results (a flame that will heat nuts and bolts to cherry red)?
Rusty Nelson
Old 03-21-2018, 03:48 PM   #2
estout81
Default Re: Acetylene verses propane
I used propane for years. You can do anything but weld.Check with your local welding store for proper equipment. Yes it is much cheaper than acetylene.
estout81 is offline   Reply With Quote
Old 03-21-2018, 04:57 PM   #3
pooch
pooch's Avatar
You can braze and silver solder and weld body metal with LPG.
Heating to cherry red is no problem, just a bit slower.
I think you need an LPG heating tip, I am not sure if mine is, but it heats fine.
With plasma so cheap, it is a waste of money having acetylene there just for cutting.
pooch is offline   Reply With Quote
Old 03-21-2018, 05:08 PM   #4
mleder
Rusty - use the propane, must cheaper and safer. Easier to obtain. We torch scrap steel at our recycling yard and have used propane for as long as I remember (40 plus years) Of all the maintence heating we do to loosen and expand things we have never failed. If you want a demonstration you can come over. I'm your clubs newsletter editor in case you didn't connect the name I use on this forum.
mleder is offline   Reply With Quote
Old 03-21-2018, 07:46 PM   #5
Benson
Benson's Avatar
... qwertyuiop-96490
Benson is offline   Reply With Quote
Old 03-22-2018, 08:44 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Find a local JUNKIE & he can tell you ALL you need to know, about using Propane.
"THE ASSISTANT GURU OF STUFF"
