07-07-2021, 04:05 PM | #1 |
Spark Plug Question
I'm not going to ask which is the best, or proper, or....I'm sure I can search for that in the forum. What does puzzle me is this..... Some of the spark plugs I see listed for our cars look modern with a top such as you would use normal spark plug wires. My '28 has the bare copper strips for wires. How do I make these plugs work?
07-07-2021, 05:00 PM | #2 |
Re: Spark Plug Question
You could get a modern cap for your distributor and use modern wires.
https://www.macsautoparts.com/model-...8-20907-1.html Also on a lot of the spark plugs listed for the Model A the little tip screws off, allowing the use of the stock connectors.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 07-07-2021 at 05:10 PM. |
07-07-2021, 05:12 PM | #3 |
Here is what I did. I ordered the little brass knurled nuts that go on top of the spark plugs from https://restorationstuff.com/. (Page 3 in their catalog.) They did not quite fit so I had to re thread them and counterbore the bottom side a little to clear the unthreaded portion of the threaded part of the plugs. This is assuming that the modern connectors unthread from the plugs. You can just use the modern connectors by unthreading them but I like the look of the brass knurled nuts.
07-07-2021, 05:59 PM | #4 | |
Ruth "Sometimes you really DO need to read the whole thread" |
07-07-2021, 06:01 PM | #5 |
Just by the Motorcraft or Champion plugs. The cap unscrews. Very easy. If you need help call me. 772 341 8291
07-08-2021, 06:28 AM | #6 | |
07-08-2021, 10:12 AM | #7 |
The modern plug wires are no way as reliable as the original Ford spark plug connectors. I use plugs with a removable top nut. Looks like this:
Bob Bidonde |
07-08-2021, 10:51 AM | #8 |
07-09-2021, 07:17 AM | #9 |
Y-Blockhead,
Your plugs are looking snazzy. Nice work! Tell me about those brass ferrules you have on your plugs.
Bob Bidonde |
07-09-2021, 08:02 AM | #10 |
[QUOTE=Y-Blockhead;2034157]I prefer to "antique" mine.
Copper tubing caps ? |
07-09-2021, 10:47 AM | #11 |
Those look nice.
07-09-2021, 10:51 AM | #12 | |
Before & After Last edited by Y-Blockhead; 07-09-2021 at 11:42 AM. |
07-09-2021, 12:45 PM | #13 | |
