Old 06-08-2021, 01:01 PM   #1
Garcia
Garcia's Avatar
Default Shape of popout ignition switch
I'm confused about the varieties of popout switches. The Andrews handbook shows an early style and a later style, both of which are basically cylindrical, and both of which show up on a google image search.
Over on ebay, however, there are currently about half a dozen items listed as popout switches that are basically conical.
Any ideas of where the conical switches come from and what they fit?
Garcia is offline   Reply With Quote
Old 06-08-2021, 02:02 PM   #2
Bill G
Bill G's Avatar
Default Re: Shape of popout ignition switch
The ones you call "conical" might be the switch that is offered as an inexpensive replacement on-off switch if the pop-out switch is missing or not existent. Without pictures of what you are seeing in eBay, it is hard to answer your question.
Bill G is offline   Reply With Quote
Old 06-08-2021, 03:00 PM   #3
Garcia
Garcia's Avatar
Does this help?
Kind of reminds me of the Mercury space capsule.
Old 06-08-2021, 03:41 PM   #4
700rpm
700rpm's Avatar
If you’re looking for an original, that isn’t one.
Ray Horton, Portland, OR
Old 06-08-2021, 06:43 PM   #5
jw hash
jw hash's Avatar
that is NOT a pop out, it is just a on off replacement switch.
jw hash is offline   Reply With Quote
Old 06-09-2021, 08:31 AM   #6
rotorwrench
rotorwrench's Avatar
The model A used the ELECTROLOCK switch assemblies through the entire production. The head was upgraded and the armored cable was changed several times as well due to changes in the bodies and different dash panels. I have no idea how many aftermarket replacements were made over the years but I would venture to say there were more than most of us know. Not all were armored and not all were pop out designs. Reproduction "pop outs" were available at different times by different manufacturers but they are no longer produced as far as i know. The ones made in Spain in the 1970s & 80s are likely the most common of the reproductions.
If it doesn't look, function, and break down for repair exactly like one of the original two model A designs, it is not an original. Many of them had a tag with manufacturing information but the tags have been reproduced and not all of them had tags There were several different end fittings and clamps depending on year of manufacture. All this stuff is in the judging standards.
GM and other manufacturers use Briggs & Stratton ELECTROLOCK designs but they are different than the Ford designs. Not all of them are pop out types.
Old 06-09-2021, 11:21 AM   #7
Jim Mason
Jim Mason's Avatar
http://jmodela.coffeecup.com/switches.html
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
