Old 02-12-2020, 12:16 PM   #1
Steve Plucker
Default Restoring the Carburetor Inlet Filter Screen
Sometimes you can remove the Carburetor Inlet Filter Screen from the carburetor with no problems and if in good condition you can reuse it.
However a lot of times the removal is not so great thus the assembly is not usable so you discard it and put in a reproduction and you are done with it.
This brings up the question of restoring the original assembly.
The only thing that is useable is the original nut weather it be brass or steel.
The problem is finding a new screen and end assembly to insert into the original nut if the nut is in good condition without any marks on the edges.
SO...where can we find just the screen and end assemblies to do this?
I do not think the repro houses offer this part by itself...do they?
So unless they can sell just the screen and end...I guess we are stuck with reproduction assemblies of the Carburetor Inlet Filter Screen assembly!
I will contact some of the repro houses on this.
Pluck
Old 02-12-2020, 02:16 PM   #2
arnhemmer
Default Re: Restoring the Carburetor Inlet Filter Screen
Snyders part number A-9559 B OR S Depending if you want the brass or steel version.
arnhemmer is offline   Reply With Quote
Old 02-12-2020, 06:55 PM   #3
redmodelt
redmodelt's Avatar
He want to just replace the screen not the whole assembly. Don't recall seeing just the screen. While the screen itself would not be hard, it would be the rolled piece on the end that would take some searching to find a replacement. Or you could save and clean some old ones and just replace the screen material.
Old 02-12-2020, 11:38 PM   #4
Brentwood Bob
That end piece gets stuck , rusted in place.
Brentwood Bob is offline   Reply With Quote
Old 02-12-2020, 11:54 PM   #5
Steve Plucker
Yes it does and sometimes it is hell getting out!
Old 02-13-2020, 01:08 AM   #6
Brentwood Bob
One tool I made, or picked up is a modified 16 Penney nail ground to a almost blunt end with a partial bend to knock the brass Ferrell back toward the inlet from the float valve end.
Might be useful.
Old 02-16-2020, 10:13 AM   #7
Shemp
From Snyder's:
STRAINER SCREEN ONLY
A-9559
28-31
Screen only if you want to use your old hex for the carburetor strainer. Zenith only. 1928-31 USA
Quantity:
$4.95 EA
Shemp is offline   Reply With Quote
