05-19-2019, 05:27 PM | #1 |
Ford Hi-Compression Head Dated 1936
Ok, I have one more "A" head which is mold dated 1936 which has the same looks as the Police Heads that I have that are cracked. Are they from the same mold, and the same Compression as the Police ones.. No "B" on it .. And its not a 1932 Head..
05-19-2019, 07:33 PM | #2 |
Re: Ford Hi-Compression Head Dated 1936
1936 model a service head,stock combustion chambers..does your '36 head have heart shaped chambers? |
05-19-2019, 09:40 PM | #3 |
Yes, It is all the same in and out as the Police Head, except for the date marked on the top & No "B".. Also No #s or Script as your show. I have several of them..
05-19-2019, 10:00 PM | #4 |
So the business side looks like this? nice.The 1936 service head I have is a stock A design,it appears to be a better quality casting than an original Rouge head..if you have the heart chambers you have some period speed gold brother. |
05-19-2019, 10:32 PM | #5 |
Yes, That is it !! What gasket is used with it ??..
05-19-2019, 11:39 PM | #6 |
05-20-2019, 12:01 AM | #7 |
You will probably find the Model B gasket matches the combustion chamber better.
Charlie Stephens |
05-20-2019, 09:09 AM | #8 |
Do you mean the Standard 32-34 Model B Gasket ?? The same one used on the Police Head ??.. Would this head also be the same compression of 5:22 like the Police Head..
05-20-2019, 09:52 AM | #9 |
05-20-2019, 01:08 PM | #10 |
I have compared the Best graphite combustion chamber shape and they are the same. Difference only the 2 vent holes between cylinders 2 and 3. 509 is the number for the graphtite A gasket.
05-20-2019, 03:16 PM | #11 |
Can you measure the volume of the police head you have and compare to the head your asking about? That will tell you if the ratio is the same.
