Old 08-08-2018, 07:22 AM   #1
Ray64
Ray64's Avatar
Default Gas leak
Going to change all gas lines and settlement bowl today. Any hint as to what to use as a fitting sealant Most are compression type but a few threaded Tnx RAY
Ray64 is offline   Reply With Quote
Old 08-08-2018, 11:12 AM   #2
Jim Brierley
Default Re: Gas leak
Compression fittings do not require any sealant, just lube the threads a little for easier turning of the nut.
Jim Brierley is offline   Reply With Quote
Old 08-08-2018, 10:39 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What do you mean by threaded? Like a pipe thread? Or like a flare fitting, which doesn’t need anything but oil.
Old 08-08-2018, 11:33 PM   #4
Chuck Sea/Tac
Old 08-09-2018, 10:35 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
The main gas valve coming out of the gas tank is the only threaded fitting I can think of. It has a ¼" pipe thread. I used "Yellow" pipe tape.
Old 08-17-2018, 10:19 PM   #6
pbishop
Yes, use thread tape on those fittings that are straight threads - pipe-thread fittings would be self-sealing as would be compression gland fittings.
pbishop is offline   Reply With Quote
Old 08-18-2018, 08:31 AM   #7
Bob-A
Bob-A's Avatar
Thumbs up Re: Gas leak
I use Aviation-Permatex thinned with a little denatured alcohol. On all my "A" gaskets including threads.
Bob-A
Bob-A is offline   Reply With Quote
Old 09-15-2018, 11:21 PM   #8
28Ca8149
I had a car that had a hole in the bottom of the gas tank from being hit with a rock We were miles from anyone and it was leaking fast .I had a tube of Seal All ,so I grabbed a cleanex soaked it with the glue ,held it for a few minutes and it stopped leaking .We drove the car for a few years and I never touched the tank again .we allways carried a tube in the trucks for radiater leaks .
28Ca8149 is offline   Reply With Quote
