Old 05-21-2017, 05:05 PM   #1
California Charlie
California Charlie's Avatar
Default Sunday project-front spindle question
I'm working on my front axle/king pin assembly and I'm having a problem getting the Felt Washer and Cup to fit in-between the spindle and lower front axle. There is small space for these to fit in, but it's very tight and wondering if there is a certain way this is done with perhaps temporarily collapsing the Felt Washer someway, or some other trick that you with this experience have. Thanks for all those who may chime in to provide me some help with this matter.
California Charlie is offline   Reply With Quote
Old 05-21-2017, 05:16 PM   #2
lindy williams
Default Re: Sunday project-front spindle question
Many of those cups are too tall and will not fit. Bratton's is selling one that he claims is correct and will fit. $.65 each.
lindy williams is offline   Reply With Quote
Old 05-21-2017, 05:18 PM   #3
California Charlie
Thanks, That gives me an idea that I may check the condition of the ones I removed.
Old 05-21-2017, 05:43 PM   #4
1955cj5
1955cj5's Avatar
I reused the old cup with the new felt.
Even then there was a trick...
Hold the felt and cup washer against the bottom of the axle with one hand.
Tilt the spindle towards you...outward, so the bottom just contacts the cup washer, then roll/tilt the spindle so the top slides over the axle...
Wish I had taken pictures!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-21-2017, 05:50 PM   #5
JBill
Geez. I didn't have any trouble, which of course makes me think I must have done it wrong!!!
JBill is offline   Reply With Quote
Old 05-21-2017, 06:17 PM   #6
California Charlie
Smile Re: Sunday project-front spindle question-FOUND A FIX
Found a fix-This worked for me:
-I glued the Felt to the Cup
-I greased the Felt
-I clamped the Cup and Felt in-between two pieces of wood to compress the Felt. I left the pieced clamped together for a little while.
-I removed the clamped components and was then able to inset the Cup and compressed Felt in-between the spindle and lower front axle.
-I then tapered the bottom of an old King Pin and inserted it into the bottom of the axle to line up the Cup and Felt.
-I drove my new King Pin into the top of the axle knocking out the old King Pin keeping the Cup and Felt alignment in place.
-Now ready to do the other side. Happy Camper!
Old 05-21-2017, 10:09 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Brother Californian,
The Moral of the story: "DON'T EVER THROW AWAY OLD ORIGINAL PARTS"
Bill Junkie
"THE ASSISTANT GURU OF STUFF"
Old 08-21-2017, 10:24 PM   #8
Rb63
Hey guys, I have the same issue, order parts.....waiting.
Thx
Rb63 is offline   Reply With Quote
Old 08-22-2017, 07:17 AM   #9
Norm M
I installed a new spindle in my Tudor (the old spindle nut threads were stripped). I employed a similar solution by using a deep socket which had an O.D. about the size of the spindle I.D. and inserted it from the bottom. Then I stacked the felt washer and cup, the the spindle; after pushing the spindle into place which is indicated when the socket can be slid through to the top spindle bushing, I then simply slid the kingpin in from the top. Worked like I knew what I was doing.
Norm M is offline   Reply With Quote
Old 08-22-2017, 08:59 AM   #10
100IH
Several times I have had to grind the edges down to fit so the edge has enough clearance, Don' want it contacting. Thinner sheet metal would have been batter.
100IH is offline   Reply With Quote
Old 08-22-2017, 10:39 AM   #11
Fullraceflathead
Fullraceflathead's Avatar
Mine were a little pain in the azz but a few "Choice Words" helped me a lot!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
