10-01-2023, 01:56 PM | #21 |
Re: Cheap bias ply tires ?
Diamond Back tires in their early years sold truck tires for classic cars. I have a set on 46 rims that have no sidewalk markings (the hot rod guys like that like me) and wear like iron. But, 6-ply tires are made for trucks and your ride will be affected. They do wear much better than classic tires that’s for sure …. I tend to run them a little soft for a better ride.
Presently Maxxis (sp?) makes the old Austone British taxicab tire - not cheap but they wear much better than a classic car tire and figuring the cost per mile, they are worth the extra money ….
Run to the LA Roadster Show - 2016 My Run to Bonneville - 2013 My 32 5-Window Build My Run to the LSRU Last edited by TomT/Williamsburg; 10-01-2023 at 02:01 PM. |
10-01-2023, 04:31 PM | #22 |
No need to be concerned or confused about the term ply-rated. That has been around for decades. I remember seeing an even number followered by PR on tires of long-parked vehicles when I was a kid.
I dig coal, which provides motivation for EVs. |
10-02-2023, 05:16 AM | #23 |
I've run 6 ply rated tyres on my lightweight roadster ever since I built it. They are ok but it is not built for comfort.
It is worth mentioning that the original poster Harold is not in the USA so directing him to WalMart is not particularly relevant. |
10-02-2023, 05:41 AM | #24 |
The Firestone in Europe cost 400€/ea !
I found two other tires, they are radial and not bias ply but are 12ply. https://www.centralepneus.be/pneu-au.../?orderby=prix |
10-09-2023, 08:59 AM | #25 | |
Sidewall thickness isn't going to play a roll in longevity. As stated by others, trailer tires are designed for load capacity, hence the thicker sidewall. They aren't designed for power transfer (acceleration or braking) or handling (both wet and dry or at varying temperatures and speeds), hence the thicker sidewall and different tread shape. Most trailer tires are also only rated for 75 mph. That's freeway speed (or slower) in most states. They don't belong on a passenger car.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
10-13-2023, 08:03 AM | #26 |
Walmart is all over the world. Everything isnt just about the US. My tires serve me fine. Some of you guys overthink a lot of things........ |
10-13-2023, 09:19 AM | #27 |
The Maxxis tire was made in Taiwan and had a better reputation than most of the Chinese may pops in the rv world. My trailer came with some no name Chinese tires, sun was only on them the short distances we traveled, covered the rest of the time. Couple thousand miles and 5 years later big bulges from the sidewalls. They were not overloaded, they just have a 5 year life.
