06-03-2020, 05:11 PM | #1 |
'53 Fuel Sender
I have spent the last couple of months working through my '53. Completely re-wired the car i.e. new dash/engine and O/D looms, fitted relays in the headlight circuit, installed factory turn signals etc. Now I have a faulty fuel sender unit that I need to replace.
Michael at Third Gen has new replacements and I wonder if anybody can advise as to the pros/cons of these replacements? I am tempted to try to find a good used original as opposed to using a new unit of unknown quality. Any advice would be welcomed. https://thirdgenauto.com/product/new...unit-assembly/ Here's a link to the first fire up of the engine since solving a stuck valve issue. This car had been in a barn in Oklahoma for more than 30 years prior to me buying it and importing it to New Zealand. https://www.facebook.com/meric.hoffm...60614102261840 Enjoy
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
06-03-2020, 05:20 PM | #2 |
Re: '53 Fuel Sender
Don't think it is a quality issue, but more of a different mode of operation. All of the modern replacement units are resistance types. Original would be great if you can find one in working or repairable condition, otherwise resistance is about all there is.
06-03-2020, 09:01 PM | #3 |
Re: '53 Fuel Sender
Thanks JSeery, I think I will try to find a salvageable used one.
06-03-2020, 09:14 PM | #4 |
Re: '53 Fuel Sender
New replacement senders just don't work accurately. Don't waste your money.
06-04-2020, 02:52 PM | #5 |
Re: '53 Fuel Sender
Thanks for the heads up. I had thought that, hence why I posed the question. This is a great place for technical support
06-04-2020, 02:58 PM | #6 |
Re: '53 Fuel Sender
Gas Tank Sending Units. Here's a start. https://www.fordbarn.com/forum/showt...k+sending+unit |
06-04-2020, 03:14 PM | #7 |
Re: '53 Fuel Sender
I have successfully repaired King-Seeley temperature senders. I have never done a fuel sender, but since they work on the same princilpe, perhaps thay can be fixed too. Clean and adjust the points for a start.
06-04-2020, 09:35 PM | #8 |
Re: '53 Fuel Sender
Thanks for the advise, I will try pulling it out this weekend and have a play
06-04-2020, 09:43 PM | #9 |
Re: '53 Fuel Sender
meric42:
Actually it, pretty interesting to see how it works. Be very gentle and patient. |
06-04-2020, 09:54 PM | #10 |
Re: '53 Fuel Sender
Here is what they look like inside. I would start by just cleaning the contacts and see how it works. The first photo is 19Fordy's and the 2nd one is mine.
06-05-2020, 03:40 AM | #11 | |
Re: '53 Fuel Sender
06-05-2020, 08:22 AM | #12 |
Re: '53 Fuel Sender
meric. I salvaged a KS sender from a '51 for my '46. I cleaned the contacts with 1000 grit paper, then slid a strip of printer paper through to remove any residual. I did cause myself some problems, as you will note, if you read the link below. Don't lose the little button!
https://www.fordbarn.com/forum/showt...ghlight=Sender |
06-05-2020, 04:16 PM | #13 | |
Re: '53 Fuel Sender
06-08-2020, 04:02 PM | #14 |
Re: '53 Fuel Sender
* UPDATE *
Just to let you guys know, I had to remove the fuel tank from my '53 as is is full of crud (different story), so with the tank now out I decided to remove the sender and see if i could get it operational. Removing the screws being the first obstacle, lots of penetrating liquid and many strong words later out it came. The first problem was that the float has been almost completely dissolved by whatever had been in the tank over the last 30 - 40 years with just enough of a ring of the float remaining to cling to the hook on the end of the arm. Secondly the surface rust on the underside of the unit and the wire arm meant that it could not move freely at all. After lots of cleaning and lubricating, the arm now moves freely. I popped the top off to find everything inside, clean and in perfect working order. I then refitted the top, hooked the sender up to the wiring and a temporary ground clip lead to find that the sender seems to work fine and looks to be calibrated correctly. Another float was found from an old unit, so the sender is now ready to be reinstalled once I clean and treat the inside of the tank of course. Thanks to all contributors above for their helpful suggestions. PS: I will take pic's and post these later if anybody's interested
06-08-2020, 04:41 PM | #15 |
Re: '53 Fuel Sender
I just went through the same process with my 51. Tank full of rust, underside of sender also rusted and not moving, float completely dissolved (chemically etched by rust, I'm guessing). Just finished cleaning and resurfacing the tank with PQR-15. I also managed to de-rust the sender and got it moving smoothly. Just to help against future rust, I coated the arm and the outer surfaces of the lower half of the sender with a thin coat of PQR as well. I also popped the lid of the sender and found everything to be clean inside. It seems the critical part of the sender, the flexible metal membrane that allows connecting the rod movement to the electrical bits, is completely impervious to rust or corrosion. That helps a lot in getting these working again.
06-08-2020, 09:34 PM | #16 |
Re: '53 Fuel Sender
Here's the pic's
