11-04-2018, 05:56 PM | #1 |
'41 Car Drag Link differences
Being a relatively new '41 Business Coupe owner I have noticed that there are two different drag link configurations. Are they interchangeable? If not then do they require a different pitman arm? The 'bent' end type seem to be commomly available and somewhat cheaper on Ebay. Does anybody know the reason for the difference?
Cheers, Meric.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 |
11-04-2018, 07:48 PM | #2 |
Re: '41 Car Drag Link differences
The one with the sharp offset on the rod end fits a '41 car, others won't, due to the '41 steering arm eye tapering from the top down.
11-04-2018, 10:10 PM | #3 |
The front end changed early in the '41 model year, including the spring and axel setup, and the drag link. I have an early model year '41; the one with the three piece front fenders and without the extra chrome pieces on the fenders and over the grill. The drag link is the early configuration, fitting back to 1935, with only a slight bend. There is another drag link listed for only the 1941 model year that has a big offset at the pittman arm end. That is for the later part of the '41 model year only. They are not interchangeable.
11-04-2018, 10:24 PM | #4 | |
11-05-2018, 08:24 AM | #5 |
It should also be noted that this is the situation ('41 Fords with the drag link mounted from the TOP) where you have ROUND BACK spindles like all '37-'40s, except that the drag link hole on the passenger-side spindle is tapered from the top, rather than from the bottom like '37-'40. These won't work on a '37-'40 because it'll cause the drag link to interfere with the wishbone. So, be careful when buying round-back spindles on eBay or at a swap meet. '41s also have a one-year-only wishbone that is about four or five inches longer than a '37-'40 WB. DD
11-05-2018, 08:45 AM | #6 | |
11-06-2018, 06:36 PM | #7 |
My 41 has the drag link mounted from the bottom on both sides with nut on top, pittman arm is the same on passenger side. The spindles are round on both sides, I'll have to do some checking to see if it's early or late model since chrome has been removed. Al
11-07-2018, 08:40 AM | #8 | |
Sounds like EARLY to me. DD |
11-07-2018, 09:44 AM | #9 |
Metric: when your car arrives, check the glass for date codes, my '41 has March and April 1941 codes. It was my understanding the 3 piece fenders were used in September of 1940.
Thread Tools | |
Display Modes | |
