05-21-2016, 12:47 PM | #1 |
Transmission gear ratio
I Need help! I am a newby. I need to know where to find the gear ratio for first and second gear for a 28 Ford coupe.
Part 2: Has anybody used clings bell housing conversion to V8 trans? Thanks in advance for any help! |
05-21-2016, 05:50 PM | #2 |
Re: Transmission gear ratio
Just see how many turns it takes on the input shaft, to turn the output shaft 1 turn, in each gear.
Bill W.
05-21-2016, 05:59 PM | #3 |
Hi BRU and welcome! If I remember correctly 1st gear is in the 3.00 range and 2nd in the 2.00 range with 3rd 1 to 1.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
05-21-2016, 06:05 PM | #4 |
Standard
1st 3.12:1 2nd 1.85:1 3rd 1:1 |
05-22-2016, 09:29 AM | #5 |
Harley,
Reverse is QUITE low, for safety in backing up. Wonder what ratio it is? Bill W.
05-22-2016, 10:41 AM | #6 |
