Old 08-29-2018, 10:02 AM   #1
Art Newland
Art Newland's Avatar
Default Strange Transmission Modification
I've been in the process of moving and going through my old car stuff. I had this spare transmission and was looking it over to see if it was worth a hoot and noticed the strange large gear welded on to the input shaft. A corresponding small gear is welded to the cluster gear. Any idea why?
"whatever works!"
Art Newland is offline   Reply With Quote
Old 08-29-2018, 10:16 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Strange Transmission Modification
Overdrive
Old 08-29-2018, 10:48 AM   #3
Hoovercw
Following this. I have never heard of this before.
Hoovercw is offline   Reply With Quote
Old 08-29-2018, 10:56 AM   #4
J Franklin
J Franklin's Avatar
When you shift gears what is the action of the output shaft?
Old 08-29-2018, 11:01 AM   #5
Art Newland
I know it's hard to see, but notice the center of the cluster has been machined off.
"whatever works!"
Old 08-29-2018, 11:03 AM   #6
Bob C
Maybe an in-n-out box for racing or forward reverse for a boat.
I don't see a cluster gear at least not a whole one.
Bob
Old 08-29-2018, 11:04 AM   #7
Art Newland
It appears that the only functions are straight through like normal third gear, and reverse engaged and not engaged. And reverse is either 1 to 1 or very close.
"whatever works!"
Old 08-29-2018, 11:05 AM   #8
Art Newland
The boat idea makes some sense.
"whatever works!"
Old 08-29-2018, 08:05 PM   #9
jw hash
jw hash's Avatar
it looks like it was made to run at a high speed in reverse and direct drive forward. they have machined off low and second gears off the cluster gears. I will go with a boat.
jw hash is offline   Reply With Quote
Old 08-30-2018, 09:48 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Strange, but using it to operate a boat or winch does seem to make sense. Still, for a boat or winch, I'd have used a stock tranny.
Old 08-30-2018, 10:18 AM   #11
Art Newland
Unfortunately, I can't see much of a reason to keep this in my "collection". Can't see much of any use for anything...
"whatever works!"
Old 08-30-2018, 11:18 AM   #12
Tom Wesenberg
There are some good parts to be saved. Don't throw it away, but pass it to someone that would use or save the good parts.
Old 08-30-2018, 11:19 AM   #13
J Franklin
J Franklin's Avatar
Save or sell the good parts.
