Old 06-12-2018, 12:00 PM   #1
Art Newland
Art Newland's Avatar
Default F1 Fan bearing
While getting things together to put the engine back in my F1, I was showing the fan bearing to a friend of mine. I was telling him how it has to be lubricated and etc, and he volunteered to make me one for ball bearings. He has some large machining equipment. We removed the cone shaped part inside the original pulley set up. Shouldn't be able to tell it from original, all the changes are inside to factory tin parts.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 06-12-2018, 01:08 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: F1 Fan bearing
Some 8BA fans use double row bearings that are about the same as those in a water pump. I have used a universal water pump shaft & double row bearing to repair them before. The old oiler type fan shafts will last a very long time if a person services it by the Ford Chart. There are individual parts available for them as well for folks that need a repair item. Sealed bearings last a long time too.
Old 06-12-2018, 08:51 PM   #3
Art Newland
I have three of these original bearings and maybe one is usable. The all aluminum (no worries) assembly on the vendors sites is nowhere to be found. This one is built from a couple of bucks of scrap-yard steel. I'm looking forward to giving this one a try.
"whatever works!"
Old 06-12-2018, 09:29 PM   #4
19Fordy
19Fordy's Avatar
I commend you for what you are doing. 20 years ago I replaced that fan hub with one I made out of a 6 inch chunk of 6061 aluminum and 2 super heavy duty sealed ball bearings riding on a new shaft. Saved the sketches for the fan carrier swivel but not the pulley. Still working fine. Drake also sells a new aftermarket unit using better bearings. The entire story plus lots more interesting info. is here:
https://www.fordbarn.com/forum/showt...3600&showall=1
Old 06-12-2018, 09:36 PM   #5
Art Newland
I looked at turning one out of 6061 but was shocked at the cost of a chunk of aluminum that big! This part only replaces the bearing, still using the stock pulley so it looks stock from the outside.
"whatever works!"
Old 06-12-2018, 09:45 PM   #6
Ross F-1
Ross F-1's Avatar
Nice work by all! Now... can you figure out an alternative to the nightmare that is adjusting the fan belt while leaning over fat fenders?!
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-12-2018, 09:54 PM   #7
Art Newland
I think a lot of people get too much tension on these belts. They are nice fat belts with lots of belt face on the pulleys. The fan in particular, since that' all that belt is turning, I pull it up with one hand and tighten the bolt with the other. Seems plenty good that way. The Model A uses a wide belt too, too much tension will destroy water pump bushing.
"whatever works!"
Old 06-12-2018, 10:21 PM   #8
19Fordy
19Fordy's Avatar
Art: So true about the very high cost of 6 inch dia. aluminum, even scrap years ago. Luckily I got left over pieces (for free) from a local aircraft company for my students to use in high school metal shop.
Those were the good days and the kids learned a lot.
Hope your idea works super duper. Consider making sketches for others to make the same fan hub modification.- Thanks.
Old 06-13-2018, 10:05 AM   #9
Art Newland
I should be able to take the CAD drawings (we used a Bridegport CNC Mill to cut the round part) and produce a printout of the file. I think this assembly could've been made from aluminum round stock and 5/16 flat plate as well.
"whatever works!"
Old 06-14-2018, 10:04 AM   #10
RalphM
RalphM's Avatar
Great idea!
Can you post more details, like bearing #s and measurements?
Thanks,
Ralph
RalphM is offline   Reply With Quote
Old 06-16-2018, 09:04 AM   #11
Art Newland
Still working on a drawing. Brought all the parts back home and assembled every thing, sure looks like it ought to work.
"whatever works!"
Old 06-16-2018, 10:09 AM   #12
Art Newland
the bearings used;
https://www.vxb.com/ProductDetails.a...tCode=Kit14450
"whatever works!"
Old 06-16-2018, 10:21 AM   #13
Art Newland
The stock shaft wasn't quite .750, if you could find a bearing that fit the shaft you wouldn't need to make a new shaft. I suppose depending on wear, they're all a little different.
"whatever works!"
Old 06-16-2018, 11:41 AM   #14
RalphM
RalphM's Avatar
Thanks, one question, once you have this all put together, can the bearings be changed? It looks like the rear bearing would be easy, but the front bearing would not.
Old 06-16-2018, 12:05 PM   #15
Art Newland
Just take it back apart, slide the shaft out, then you could push each bearing back out. Rob had mentioned to me that if you wanted to be able to take the bearings out without damaging them, it would be a good idea to put a relief on either side behind each bearing so you could get a punch on the outer race.
"whatever works!"
Old 06-16-2018, 01:03 PM   #16
cmbrucew
cmbrucew's Avatar
RalphM
NSK 885586 is the universal water pump shaft with the bearings.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-16-2018, 01:36 PM   #17
tubman
tubman's Avatar
I have used one of the above to repair a noisy fan assembly on my '51. You need a press and the shaft has to be trimmed, but they're what works.
Old 06-16-2018, 01:38 PM   #18
Art Newland
You talking about the fan pulley for the later model cars with skinny belts?
"whatever works!"
Old 06-16-2018, 01:43 PM   #19
Art Newland
Rob sent me a couple "what he would do different" update files.
"whatever works!"
Old 06-16-2018, 01:48 PM   #20
Art Newland
I don't think it's on the drawings, but he made a collar with a set screw that goes behind the rear bearing. the original idea was to lock it down with a little clearance for expansion. I think however, I'm going to make a bushing that will press on the inner race with a wave-washer behind it so it can't rattle in there. I hate stuff that rattles... 8^)
"whatever works!"
Thread Tools
Display Modes
