Old 04-26-2018, 03:34 PM   #61
Gideon
Gideon's Avatar
Default Re: 8RT pulling the heads
I'm wondering if I should pull the heads off my 8RT milk truck motor. I'm also afraid I'll just be opening up a can of worms.
Gideon is offline   Reply With Quote
Old 04-26-2018, 03:58 PM   #62
Art Newland
Art Newland's Avatar
If it's running OK, I wouldn't. Mine missed at idle and it drove me crazy. A leak-down test (or at least a compression test) would tell you a lot.
"whatever works!"
Art Newland is offline   Reply With Quote
Old 04-26-2018, 06:39 PM   #63
Art Newland
I ran my "new to me" engine some more today. It starves for fuel at about 1000 rpm, either the electric fuel-pump on the stand isn't doing it's thing, filter is plugged, or the carb has got crud in it, it looks spotless down the throat. It's not a Holley 94, it's marked "EC" and "1 1/16". There appears to be a PVC valve on it. And it has the "oil filter to no-where".
"whatever works!"
Old 04-26-2018, 10:41 PM   #64
Ross F-1
Ross F-1's Avatar
That would be the Holley 2110, used on Y-blocks. It is based on the 94 but with some improvements and higher flow, bigger throttle bores and venturis.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-26-2018, 11:36 PM   #65
Art Newland
So since everything I've read about "load-a-matic", this 2110 works OK with the stock distributor? How about the PVC, does it screw up the sensitive vacuum needed to operate the LAM?
"whatever works!"
Old 04-27-2018, 02:45 AM   #66
tubman
tubman's Avatar
If it's got the port on the back, it's designed to function properly with a Load-a-Matic. I have had a number of both kinds apart and cannot see how there could be a significant difference on how they operate. About a PVC valve interferring with the distributor vacuum, that is something I have never even considered; perhaps someone else ("Bubba"?) may be able to shed some light on the subject.
Old 04-30-2018, 03:49 AM   #67
Art Newland
Moved my fuel pump and carb (7RT) to the new engine and its got pretty good throttle response now. The spark plugs are pretty carboned up, I'll probably just replace them.
https://www.youtube.com/watch?v=A-BwooaXbqs
"whatever works!"
Old 05-14-2018, 04:04 PM   #68
Art Newland
While waiting for a few more parts to show up so I can start installing the new engine, I've turned my attention back to the "red neck" rebuild. While putting the last fine touches on the valve lash, out of the corner of my eye I noticed a distinct difference in the casting up inside the Canadian block I bought.
"whatever works!"
Old 05-14-2018, 04:44 PM   #69
Ross F-1
Ross F-1's Avatar
I've seen them both ways. On some it appears that when they machined the hole for the WP it took out part of that, on others it appears to have completely removed it.
Old 05-21-2018, 11:51 PM   #70
Art Newland
Getting some pistons!
"whatever works!"
Old 05-21-2018, 11:57 PM   #71
Tinker
Tinker's Avatar
I'd remove the idea of the vacuum advance dizzy by going with a bubba unit. Then you can also run any carb or more if you like. Not a 8ba guy btw.
Nice work and project!
Old 06-07-2018, 06:04 PM   #72
Art Newland
Haven't had loads of time to work on flathead projects but the old engine is re-assembled as a short-block and will go on the test stand after I get my new engine installed in my pickup. I'm swapping oil pans/pickups now, new engine came with an 11 inch clutch that looks brand new, the truck came with a 9.5 inch hybrid setup but has had some oil on it. I'd like to put the 9.5 inch back in but the new 11 inch is calling to me. I went over things under the pan with a torque wrench to be sure and all looked good. The crank is marked with EAB, I believe that means late model 239, correct?
"whatever works!"
Old 06-07-2018, 06:38 PM   #73
Ggmac
Nice . Keep up the good work and hope it purrs like a kitten
Ggmac is offline   Reply With Quote
Old 06-07-2018, 06:39 PM   #74
JSeery
JSeery's Avatar
Depending on your objectives the 9.5 would probably be the better option.
Old 06-07-2018, 06:48 PM   #75
Art Newland
Yea, will be just a drive for fun kinda truck, undoubtedly my left leg would thank me later for the 9.5 unit. Doesn't appear to be something you can just run out and buy/order however. I'd have to send it out to be re-lined... any recommendation?
"whatever works!"
Old 06-07-2018, 07:35 PM   #76
tubman
tubman's Avatar
Fort Wayne clutch. I got my last one there and the clutch in my '51 is the best it's ever been.
Old 06-08-2018, 01:25 PM   #77
B-O-B
B-O-B's Avatar
Ft Wayne is the best. Quick turn around also.
B-O-B is offline   Reply With Quote
Old 06-08-2018, 03:14 PM   #78
Art Newland
I'm also thinking about locating a flywheel for a 10 inch clutch and just putting it back stock... seems like someone went to a lot of trouble to get a 9.5 inch in there. I know the flywheel could be drilled for a different pressure-plate, I might check into that as well.
"whatever works!"
Old 07-16-2018, 02:14 PM   #79
Art Newland
Got her looking pretty.
"whatever works!"
Old 08-22-2018, 02:51 PM   #80
Art Newland
After 10 months my F-1 is drive-able again.
https://www.youtube.com/watch?v=Wy64_gtj54o&t=52s
File Type: jpg 0FBC8559-00D6-46A9-BE29-11787B33AA1C.JPG (91.3 KB, 11 views)
"whatever works!"
