Old 11-14-2016, 07:28 PM   #1
Dick Steinkamp
Dick Steinkamp's Avatar
Default Engine + Trans Install
Is it possible...if so are there any tricks...to installing the engine and transmission as a unit?
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 11-14-2016, 07:34 PM   #2
tbirdtbird
Default Re: Engine + Trans Install
yep
done it several times
old timer showed me.
at least with a stock head, it was strong enough to put your lifting eye in hole #3, gives perfect balance.
there have been some on here that said they tried that with a repop head and the head broke apart
'31 180A
tbirdtbird is offline   Reply With Quote
Old 11-14-2016, 07:40 PM   #3
SeaSlugs
SeaSlugs's Avatar
I dont like the idea of $2000 hanging by a single spark plug hole, I used several straps (4 i think)the first time, 2nd time I used #1 and 4 holes and lifted above the 3, I also had to use a chain around the lower water neck up to my lifting hook to keep it level side to side.
Its OK if it tilts back a little - your gonna want that to line up the U joint. Should slip right on. You may have to lower it till the front motor mount is just about ready to touch the oil pan to get it to slip on. DO NOT stick your fingers in there to help align the U joint - it will slip on and crush your fingers faster than you think. Use tools or wood sticks.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 11-14-2016, 07:41 PM   #4
Synchro909
Synchro909's Avatar
I've done it with a repo head but I don't use the hook arrangement in #3. I use a couple of ropes tied off separately. One goes behind the crank pulley, the other between the back of the sump and the flywheel housing.
Now for a word of warning: When you align the spline in the universal with the drive shaft, DON'T put your fingers in there. When they line up, they can slide together very quickly and with enough force that the ends of your fingers will be left in there. It might take a little fiddling but I use a screw driver and pointy nosed pliers - what ever works. I want to keep my fingers coz I like to scratch when it itches.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-14-2016, 09:32 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
With the body off I install them together, but with the body on I've always installed them separately.
Old 11-15-2016, 07:12 PM   #6
1931 flamingo
1931 flamingo's Avatar
2000 lbs
Are you sure.
I used a 1/2 ton chainfall when I put the olds in my deuce coupe.............
Paul in CT
Old 11-15-2016, 07:15 PM   #7
Dick Steinkamp
Originally Posted by 1931 flamingo View Post
2000 lbs
Are you sure.
Paul in CT
I think he said $2000. It's a good thing I'm well under that
Old 11-15-2016, 07:16 PM   #8
Fred K-OR
Fred K-OR's Avatar
There was a $ on that 2000. Think the engine and tranny is only 500 to 600 lbs. So your 1/2 ton will work.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 11-15-2016, 07:22 PM   #9
Vic in E-TN
I have used the #1 & #3 spark plug holes with a Chinese leveler that I bought years ago. It really makes the job easier. I think that H-F still sells them. I used a 1 ton cherry picker.
Vic
Vic in E-TN is offline   Reply With Quote
Old 11-15-2016, 08:37 PM   #10
wmws
I have used a leveler but had ropes going around the engine. Got it over the light bar then in on a steep angle. Get the transmission just below the fire wall then level it out and push it on in. Having a helper helps.
wmws is offline   Reply With Quote
Old 11-15-2016, 08:49 PM   #11
Dick Steinkamp
My light bar is off (only 4 bolts) so it should be even easier. I'll give it a try this weekend...hopefully with a helper!
Old 11-15-2016, 10:08 PM   #12
tbirdtbird
Dick, that s/b a cake walk
might even want to remove the front yoke for now, too
'31 180A
Old 11-15-2016, 10:55 PM   #13
Al 29Tudor
Al 29Tudor's Avatar
Our club installed an engine this year complete with clutch, housings and tranny all assembled. Body on. The frame had to be spread a little in the process. Make sure the throttle linkage is removed from the flywheel housing and the screw type lifting bracket is a dream for this job.
Al
Al 29Tudor is offline   Reply With Quote
Old 11-15-2016, 11:07 PM   #14
SeaSlugs
SeaSlugs's Avatar
the pedals and steering column can be a bear to work around FYI. once again keep your fingers away from anything that can pinch.
Old 11-15-2016, 11:42 PM   #15
Dick Steinkamp
Thanks for the tip!
Old 11-15-2016, 11:43 PM   #16
Dick Steinkamp
Al
Throttle linkage is off. I have an adjustable lifting bracket but I've always had better luck NOT using them. I might give it another try.
Old 11-15-2016, 11:44 PM   #17
Dick Steinkamp
Pedals are off the bell. I'll install them when the lump is in place.
Old 11-16-2016, 07:48 AM   #18
SeaSlugs
SeaSlugs's Avatar
ahh good, yea should be a cakewalk then. Just don't forget the turtle that covers the u joint before you slip it together. And the gaskets...
Old 11-16-2016, 10:45 AM   #19
Art Newland
Art Newland's Avatar
I like cake! I'll be there! I'll bring my BIG hammer.
Art Newland is offline   Reply With Quote
Old 11-16-2016, 10:49 AM   #20
Dick Steinkamp
Does cake go OK with beer?
