Old 01-20-2021, 08:46 PM   #1
ericr
ericr's Avatar
Default where is the most idiot-proof diagram of terminal box wiring?
many wiring diagrams I've seen are apparently some restatement of original diagrams with unhelpful particulars like showing the terminal located vertically, the ammeter is just a circle without plusses or minuses. Other diagrams are apparently from Dykes and show polarity of generator fields. Others reference connections via a plus and minus on the coil, which don't exist on repro script coils. Still other resources go into the alteration made after '28, and some of us are less interested in the "why" than the "how".
One member has pointed out a better diagram in Walt's catalog, but the catalog I have is a diagram rather tiny.
References to "driver" or "passenger" side are far easier to comprehend than a "plus" and a "minus" on a coil that don't exist.
in conclusion, is there a simple pictorial diagram outside of Shangri-la?
ericr is offline   Reply With Quote
Old 01-20-2021, 09:39 PM   #2
Jim Mason
Jim Mason's Avatar
Default Re: where is the most idiot-proof diagram of terminal box wiring?
Try this. based off the Dykes Manual
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 01-20-2021, 09:44 PM   #3
GPierce
GPierce's Avatar
See junction box.
File Type: jpg 11410AE7-28F3-43B0-AF11-244D178D5B4C.jpg (92.7 KB, 130 views)
GPierce is offline   Reply With Quote
Old 01-20-2021, 09:55 PM   #4
McMimmcs
McMimmcs's Avatar
Ill bet your fingers were tired by the time you got to the final line !
McMimmcs is online now   Reply With Quote
Old 01-20-2021, 10:27 PM   #5
Bob C
Check out this link. Look at the whole thing,there are actual picture
of the dash, terminal box, ect.
https://www.mafca.com/downloads/Semi...ex%20Janke.pdf
Old 01-20-2021, 11:45 PM   #6
ericr
ericr's Avatar
LOL well, yeah, this has been a distraction for me for years. Unlike me, the mechanics working on these cars in the day had new cars sitting in the showroom to compare.
I thought I read once that the wires can be completely switched over between the two terminal posts and everything was jake but I knew not to go there.
Old 01-20-2021, 11:48 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
That about covers it all. Thanks for the link Bob C.
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1 worth.
https://www.youtube.com/watch?v=51ufACHJMfU
Old 01-21-2021, 09:28 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
Here is my rendition of the terminal box wire hookup.
File Type: jpg Terminal Box Wire Connections For A & AA 164kb.jpg (56.2 KB, 342 views)
Bob Bidonde
Old 01-21-2021, 09:32 AM   #9
old31
Bob, that is a great diagram. Nice and simple for nice, simple people like me!
old31 is offline   Reply With Quote
Old 01-21-2021, 10:32 AM   #10
Badpuppy
Perfect drawing, Bob, but I don't recommend connecting anything else to the battery circuit. Accessories should be connected to the generator side, same as lighting, horn and wiper.
Old 01-21-2021, 10:53 AM   #11
katy
The diagram shown in posts #2 and #3 needs to be rotated 90 clockwise to put it in perspective.
Play it again Sam.
Old 01-21-2021, 11:18 AM   #12
ericr
ericr's Avatar
You rest my case but simultaneously, thanks to the members who took the time to post the diagrams.
Perhaps some members have a more innate ease with circuitry. Alas, I'm between the town drunk and the village idiot.
yYou
Old 01-21-2021, 11:25 AM   #13
ericr
ericr's Avatar
Bob, thanks for this. I feel like I have found Davy Jones' Locker, Bluebeard's Treasure Chest , the Lost Dutchman's Mine, the Amber Room, the Oak
Island Treasure, Dutch Schultz's Strongbox, etc.
Old 01-21-2021, 12:44 PM   #14
Gary Kelley
This is the most complete documentation of the electrical system I have encountered. Many things in this document that I have never seen before.
Thanks
Gary Kelley is offline   Reply With Quote
Old 01-21-2021, 02:43 PM   #15
Dan Partain
Dan Partain's Avatar
Correct me if I'm wrong, but there is a difference between the 2 diagrams, and it is the Ammeter. Every time I use the diagram in post 2 & 3 I connect my ammeter backwards and it shows a discharge when it's running, so I end up reversing the wires on the ammeter. If you visualize the ammeter as being shown from the rear on this diagram, it will be correct. Since it shows the needle, it appears to me to be viewed from the front, that's where I go wrong.
I like the diagram that Bob posted, it's easy to see how the wires on the ammeter should be connected.
Thanks for posting that Bob, I hadn't seen this one before now!
Dan Partain is offline   Reply With Quote
Old 01-23-2021, 01:04 PM   #16
jb-ob
Studying the MAFCA 'wiring seminar' which is correct, page 2 or page 5, diagram for the ammeter wiring ?
Horn wiring page 52 shows the wire terminals installed from the bottom where as I thought the correct installation was into the sides of the horn terminal block ?
In both examples, which is correct ?
jb-ob is online now   Reply With Quote
Old 01-23-2021, 03:35 PM   #17
Don/WI
Thanks for the link Bob. Great information. Don/WI
Don/WI is offline   Reply With Quote
Old 01-23-2021, 03:54 PM   #18
Jim Mason
Jim Mason's Avatar
Horn from the side.
Ammeter which every way to make it read correctly. many of the repops are backward. (Ive been told)
Fwiw, jm.
Old 01-26-2021, 05:20 PM   #19
rotorwrench
rotorwrench's Avatar
The two items that are as clear as mud are the coil and the amp meter connection. Many late type amp meters don't even have a + or - indicator stamped on. As was mentioned, if the amp meter shows a discharge when it's know to be charging then just swap the leads. On a coil, a person has to check the polarity. It can be done with a pencil lead but a polarity tester like the one Nu-Rex makes is a bit easier to use. Ford likely had a problem with polarity in the early days of the model A before that service bulletin came out in 1929 to change the coil wires around. It won't run as good if the polarity is off.
https://www.nurex.com/sparklite
Old 01-26-2021, 06:07 PM   #20
shew01
shew01's Avatar
The SparkLite is a very handy tool. I was skeptical when I first bought it, but I have used it frequently.
