Old 05-19-2016, 05:04 PM   #1
Dick Steinkamp
Dick Steinkamp's Avatar
Default Setting rear main
What are you guys using to remove and install the 3/4" nuts that secure the rear main?
tbirdtbird uses this...
"I took a 3/4" 1/2" drive socket and welded a 3/4" nut onto it and then I use a box wrench usually with a cheater pipe to set them"
Any other ideas?
Thanks!
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 05-19-2016, 05:59 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Setting rear main
I just welded a socket to a wrench. Usually to break them loose I just double wrench until they first start to move.
These pretty much eliminates using a torque wrench when putting things back together. A torque wrench really isn't needed, but, a pretty idea of getting the required 'tonnage' can be practiced with a wrench and comparing it to a torque wrench on other fasteners. But, good and tight is just fine [ about 80#]
Old 05-19-2016, 06:11 PM   #3
Dick Steinkamp
Thanks, Patrick!
Old 05-20-2016, 01:25 PM   #4
Dick Steinkamp
I experimented a little and my 3/8" drive 3/4" socket and 3/8" breaker bar worked fine. It was tight, but worked.
Old 05-20-2016, 07:46 PM   #5
Patrick L.
Patrick L.'s Avatar
Good. Good luck.
Old 05-21-2016, 06:06 AM   #6
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I found the wobbly socket extension is very helpful. Breaker bar to remove and torque wrench to install.
Dick M is offline   Reply With Quote
Old 05-21-2016, 06:51 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
In the era there were special tools made to do the job, this tool is square at one end, 12 point socket at the other
look in the boxes under the tables at the fleamarkets, this one was 1$
Old 05-21-2016, 08:45 AM   #8
Dick Steinkamp
That's the ticket!
