Old 05-23-2016, 08:31 PM   #1
shoe box Jack
Default spark plugs
looking for the # off the NGK plug. I was told that the ngk spark plugs are the best to use in a 239 ford??. JACK.
shoe box Jack is offline   Reply With Quote
Old 05-23-2016, 08:40 PM   #2
Vanspeed
Vanspeed's Avatar
Default Re: spark plugs
I ran a set in my dads 46 coupe because he said it was starting, running funny and I had a set ordered from NAPA. I don't know number off hand but it did improve the car in a drastic way, why I do not know but it ran great. I will look for the number.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 05-23-2016, 08:44 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
I believe it is NGK B6L - should be a direct replacement for a Champion H-10
Old 05-23-2016, 08:45 PM   #4
Vanspeed
Vanspeed's Avatar
Yep, that is it I beleive.
Old 05-23-2016, 09:04 PM   #5
38 coupe
38 coupe's Avatar
I prefer Champion 844 plugs, other folks prefer Autolite 216s.
Old 05-23-2016, 11:33 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Currently these are the best that I have used.----
http://www.fordbarn.com/forum/showthread.php?t=192185
Old 05-24-2016, 12:24 AM   #7
Drbrown
Drbrown's Avatar
My '47 59AB came with Champion H-11 in it and are still running well. Seem to burn correctly. May consider NKG's when ever they wear out. Although "modern" engines, have NKG's in our two 2003 1.8 turbo VW's .... first set replaced at 80,000 miles. The second set now have 35,000 on them.
Drbrown is offline   Reply With Quote
Old 05-24-2016, 06:07 AM   #8
wamnram
wamnram's Avatar
Here is a handy cross ref.
Wayne
wamnram is offline   Reply With Quote
Old 05-24-2016, 03:30 PM   #9
my4dv8
We were running NGK B-6L and having issues with occasional plug fouling on a cold start , switched to hotter B-4L problem solved, though we possibly could have got away with #5 but the #4 was on the shelf. The motor is modified some.
my4dv8 is offline   Reply With Quote
Old 05-24-2016, 03:55 PM   #10
shoe box Jack
Thanks for the info I have allways used champs but not happy with the last set I am going to try the ngk b6l. Let you no how they worked by this Oct. Thanks again. Jack.
Old 05-24-2016, 08:12 PM   #11
flat-v8
flat-v8's Avatar
B6L are the best plugs I have ever run! Autolite 437's are great but too long for stock heads.
flat-v8 is offline   Reply With Quote
Old 05-25-2016, 12:40 AM   #12
my4dv8
Remember the ABC rule ! Anything But Champion.
Old 05-25-2016, 05:24 AM   #13
Bertha
Bertha's Avatar
Thumbs up Re: spark plugs
Bertha likes the B-6L.
Bob
..."they are only original once"
Bertha is offline   Reply With Quote
Old 05-25-2016, 06:53 AM   #14
Bored&Stroked
I like the NGK B6L over any other plug that I've used - and I've used just about all of them. Just runs and lasts the best. I've never found a reason to go hotter with the B4Ls, but some folks do.
Old 05-25-2016, 10:08 PM   #15
miller91
miller91's Avatar
NGK B6L the best I have ever run. If you're running stock and 6 volt like me I like .025 gap.
miller91 is offline   Reply With Quote
Old 05-26-2016, 05:01 AM   #16
Bertha
Bertha's Avatar
X2
Bob
Old 05-26-2016, 06:03 AM   #17
JWL
I did a search for USA manufactured spark plugs and "no results found". Maybe I didn't ask the question correctly.
I have never had a problem with Champion plugs. I'm not sure why they are out of favor. Perhaps the (I think) Mexican manufacture location?
JWL is offline   Reply With Quote
Old 05-26-2016, 03:00 PM   #18
vilanar
On Navarro and Offy heads that I have B6L plugs are too short and very prone to fouling .....
vilanar is offline   Reply With Quote
Old 05-26-2016, 03:09 PM   #19
34PKUP
34PKUP's Avatar
That's what happens when you attempt to use the wrong reach plugs for the application.
34PKUP is offline   Reply With Quote
Old 05-26-2016, 11:38 PM   #20
vilanar
Yeah, previous owner did put those NGK´s , cause he didn´t knew......
