03-19-2016, 07:37 AM | #1 |
where to get 1952 Ford Truck motor mounts?
I have been searching several vendors and cannot seem to find a complete motor mount assembly (239 flathead). I see the rubber parts for the 52 mounts but not assembly. So I thought I would ask the experts for options. Is there anyone that sells the assembly? Can I use an earlier year assembly and get away with it or do I have to make modifications?
Thanks in advance Jeff
It is perfectly useless to know the right answer to the wrong question. Last edited by 52FordF3; 03-19-2016 at 07:46 AM. |
03-19-2016, 08:55 AM | #2 |
Re: where to get 1952 Ford Truck motor mounts?
Not sure what you mean by an "assembly"? Do you have a 6 cylinder truck or a V-8 truck?
03-19-2016, 09:25 AM | #3 |
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 03-19-2016 at 09:48 AM. |
03-19-2016, 09:37 AM | #4 | |
It is perfectly useless to know the right answer to the wrong question. |
03-19-2016, 09:35 AM | #5 |
All parts for the motor mount. bolt, washers,spacers, and cushions. 239 V8 Flathead.
03-19-2016, 10:00 AM | #6 |
http://www.jefftrumbull.com/default.aspx?moid=106 http://www.jefftrumbull.com/default.aspx?moid=105
03-19-2016, 10:27 AM | #7 |
You need the 52 only mounts. I believe Dennis Carpenter has them. Don't let anyone try to tell you different. Wish I had a picture so you could see the difference in the frame itself
I dig coal, which provides motivation for EVs. |
03-19-2016, 10:38 AM | #8 |
Try here--
http://dennis-carpenter.com/engine-mount/p/8L-6038-B/ http://dennis-carpenter.com/engine-mount/p/8L-6039-B/
03-19-2016, 10:23 PM | #9 | |
Hey thanks for the help!! Jeff
03-19-2016, 10:46 AM | #10 |
Looks like LMC has at least some of the parts. http://www.lmctruck.com/icatalog/fa/full.aspx?Page=85
03-19-2016, 12:47 PM | #11 |
8L indicates a Lincoln part originally. The 50 & 51 Mercury cars used a similar mount and it was also used as a front mount on some of the 6-cylinder engine applications for pickups & trucks so they changed the part number. Ill have to check my parts catalogs to find the new number.
03-19-2016, 11:43 PM | #12 |
Best bet is to advertise on the FTE site, as quickly as those guys are shucking their flatheads, someone has to have them.
'52 F-1, EAB flathead |
03-20-2016, 12:14 AM | #13 |
http://www.vanpeltsales.com/FH_web/F...rpumptypes.jpg
Which of these pumps are on your pickup? Lonnie |
03-20-2016, 02:18 AM | #14 |
Try www.steelerubber.com/restoration-parts. My mounts from them came as complete kit. Don't know if they'd have yours.
03-20-2016, 04:10 AM | #15 | |
03-20-2016, 09:06 AM | #16 |
I can't speak for the 1952 F series but I can for the Mercury set ups that I am more familiar with. The special step shank bolts are no longer available unless you luck into some NOS parts from a collector/dealer. I use aircraft bolts with the correct size bushing to fit inside the mount bushings to set the clamp up tension. Washers are a large area type that can be sourced through special hardware sources or possibly McMaster Carr or the like. When I purchase used stuff, it is generally pretty well corroded so used is a hit or miss source. If from western dry states, the parts might still be good.
03-20-2016, 12:46 PM | #17 |
try John's Salvage in Seguin Tx.. (830) 379-2092 i was out there yesterday and he still has some 52 & 53 trucks out there and may have the mount that bolts to the motor... also try Baxter's Ford Parts in Lawrence, Kansas.... (785) 842-9256 ............ this what it looks like but this one is for a later model truck although you might be able to modify this one and have it work..... http://www.macsautoparts.com/ford_tr...-and-f250.html
03-20-2016, 12:52 PM | #18 |
That's for '53 and later.
The '52-ONLY mount looks very similar to the 48-51 truck mounts, two rubber biscuits, but it has different diameters and different bolts to accommodate the mountings for the new-for-52 215 6-cylinders. Nothing else will work correctly. I'll take a picture of mine, if needed I can take one apart and measure the bolt, washers, etc.
03-20-2016, 02:38 PM | #19 |
Thanks Guys I have something to work with now. I will keep you posted when I come up with something.
03-21-2016, 08:48 AM | #20 |
Try http://www.chuckstrucksllc.com/ I got some mounts for my 52 F2 there
Dick C Erie, PA 1996 Exploder 1952 Ford F2 (Driver) 1948 Ford F1 Panel (Frame off resto-rod) 1946 Ford Coupe (Basket case) |
