Old 10-26-2011, 04:09 PM   #1
Ford46
Ford46's Avatar
Default Best home brew penetrating oil?
First, I apologize for treading over old territory, but a friend asked. What is the formula for the home brew penetrating oil? Will it last in storage?
Thank you in advance for your assistance and patience.....LouB.
Ford46 is offline   Reply With Quote
Old 10-26-2011, 04:22 PM   #2
Bassman/NZ
Bassman/NZ's Avatar
Default Re: Best home brew penetrating oil?
I use 50/50 acetone and ATF. Works pretty good. The trick to any penetrating oil is patience and perseverance.
Bassman/NZ is offline   Reply With Quote
Old 10-26-2011, 04:24 PM   #3
John Kennedy
John Kennedy's Avatar
What he said. That's the answer.
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 10-26-2011, 04:26 PM   #4
Henry/Kokomo
Henry/Kokomo's Avatar
Gotta keep it in a covered container or else the acetone evaporates. Good stuff.
Henry/Kokomo is offline   Reply With Quote
Old 10-26-2011, 08:53 PM   #5
Ford46
Ford46's Avatar
Thanks guys, asking for a friend who was having issues posting.....LouB.
Old 10-26-2011, 09:46 PM   #6
FL&WVMIKE
FL&WVMIKE's Avatar
Don't forget to shake your Acetone/Auto Transmission Fluid mixture, each time you use it. It will separate.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 10-27-2011, 01:15 AM   #7
Lanny
Lanny's Avatar
Acetone evaporates very-very quickley, fuel oil and trans fluid works Better.
Better yet, Buy a can of PB Blaster, No Muss, No Fuss, and it works as good as Anything.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 10-27-2011, 09:21 AM   #8
Ol' Ron
Ol' Ron's Avatar
I have to go with the 50/50 mix. I had a lathe with a 3 jaw chuck and it wouldn't come off. I tried everything I could think of including a torch and 6' bar. My frienf George suggested actone&ATF. Squirted alittle on it every morning for a few days and it finally screwed off by hand. Great for removing exhaust guides.
Old 10-27-2011, 09:33 AM   #9
Tim Ayers
MIKE
+1 on this.
Old 10-27-2011, 10:06 AM   #10
37ford4dr
37ford4dr's Avatar
i need to try the 50/50 mix with some grease in there....so that it wont evaporate so quickly, maybe you squirt it the area and then put the grease over it..
37ford4dr is offline   Reply With Quote
Old 10-27-2011, 08:38 PM   #11
Shadetree
Shadetree's Avatar
I used the 50/50 mix on my stuck 8RT cylinders. Everyday I took a crow bar and pryed on the flywheel resting it on the bellhousing alignment pin. After several days I saw a little movement, then a little more each day. Finally I was able to turn it 360°.
It works!
Shadetree
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
