Old 08-16-2023, 10:01 AM   #1
CT Jack
CT Jack's Avatar
Default Floormat Attachment
My front floormat is a carpet made by Lebaron Bonney which has a heavy woven backing. I am looking for suggestions on how to attach this carpet to the floor using the floor mounted attachment pins. I have tried using the press on type gripper rings offered by the parts suppliers. The supplied rings are suppose to firmly grip the carpet material but will not on my carpet. The gripper rings look like they will work but only on thinner material.
Thanks
CT Jack is offline   Reply With Quote
Old 08-16-2023, 01:39 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Floormat Attachment
did you try flattening the prongs thru the carpet and flatten on back side of carpet? Just a thought.
www.whidbeymodelaclub.com
Old 08-16-2023, 06:45 PM   #3
CT Jack
CT Jack's Avatar
Yes, that is the problem the prongs are not long enough to go through the carpet to allow then to be bent.
Old 08-16-2023, 10:14 PM   #4
bkensinger
bkensinger's Avatar
I used velcro stips from Amazon amd it works great.
/Users/RobertKensinger/Desktop/thumbnail_IMG_0296.jpg
bkensinger is offline   Reply With Quote
Old 08-17-2023, 08:41 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
These slides may help you:
Bob Bidonde
Old 08-17-2023, 09:46 AM   #6
CT Jack
CT Jack's Avatar
Bob, I will try the method used in slides you have posted.
Thanks and I will report back with results.
Jack
Old 08-17-2023, 10:51 AM   #7
Paragon
Bob, I just have to say that your illustrations add so much to so many topics. Thank you so darn much!
Paragon is offline   Reply With Quote
Old 08-17-2023, 05:35 PM   #8
chrs1961815
chrs1961815's Avatar
Those two piece ones are not the original style and don't work well IMO no matter how hard you try to get the prongs over. For a 30 Phaeton I just did I wound up buying the original style ones from berts that work much better.
https://modelastore.com/index.php?ro...roduct_id=4981
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-18-2023, 08:04 AM   #9
CT Jack
CT Jack's Avatar
Chrs1961815, I will try your suggestion. The ring I have has 3 prongs and are not long enough to engage with the mating locking piece. I will use Bob's method for compressing them. Thanks
