05-20-2020, 04:14 PM | #1 |
Kelsey-Hayes rims on new cast iron
I've installed cast iron rear drums but now my K-H rims won't fit. It seems that the new emergency/parking brake casting is larger than original. Has anybody else encountered this? What is your solution? I've been grinding the welds where the spokes join the rims, but they still won't fit. Is there an "easy" solution? Thanks. Ned
Retired civil engineer. Winters in Phoenix, summers in Ipswich, Mass. and North Dakota. '29 closed cab pickup- Excellent AZ truck. '29 roadster- Owned for 21 years but now sold. '28 CC pickup- My first car in Andover, MA back in '62- '63. |
05-20-2020, 05:23 PM | #2 |
Re: Kelsey-Hayes rims on new cast iron
Whose drums did you use?
05-20-2020, 05:37 PM | #3 |
It won't solve the problem but might give more data, will an original Model A rim fit?
Charlie Stephens |
05-20-2020, 06:16 PM | #4 |
www.whidbeymodelaclub.com |
05-20-2020, 06:31 PM | #5 |
You can only use Kelsey Hayes wheel on rear cast drums by grinding the heck out of the inner spoke ends to clear the drum. Not a cool thing to do, but if you are careful it will work.
05-20-2020, 07:24 PM | #6 |
I was not comfortable with grinding the spokes.
Tim Downtown, Ca |
05-20-2020, 11:27 PM | #7 |
I have a 31 Vicky sitting on Kelsey Hayes, I haven’t looked to see if anything was modified. Parked for 50+years. I’m told 1 is missing. I can try to get a picture.
Sent from my iPhone using Tapatalk |
05-21-2020, 07:13 AM | #8 |
Steve, how much interference is there? Can/could the drum itself be machined on the outside some to gain the necessary clearance?
05-23-2020, 08:31 PM | #9 |
Model a ford mechanics handbookvII page 4-18 Sent from my iPhone using Tapatalk |
05-23-2020, 08:40 PM | #10 |
I think I would call Randy Gross and ask him if the drums he sells clear, 714-292-8660 or email [email protected]. If so, send the ones you have back and buy from him.
Charlie Stephens |
06-20-2020, 11:19 PM | #11 |
06-21-2020, 04:05 AM | #12 |
Rotated:
06-21-2020, 04:05 AM | #13 |
Rotated:
06-28-2020, 08:42 AM | #14 |
I solved it by grinding the "bump" of the spoke welds. Not a great idea but it works. Was a real pain to do. Then painted over the grind marks.
Wish I'd have known of the problem earlier as the drums could have been truned. Ned
