Old 09-17-2021, 10:05 AM   #1
DJeffrey
DJeffrey's Avatar
Default Unknown Zenith Carburetor
I obtained a zenith carburetor core but I don't know what's it's to. The gas line is on the front of the bowl and it doesn't have an opening for the adjustment needle housing. I don't think it's a Model A carb, Model T maybe? Any help would be appreciated and thanks in advance.
DJeffrey is offline   Reply With Quote
Old 09-17-2021, 10:35 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Unknown Zenith Carburetor
Zenith made a lot of different carburetors. Harold Hicks talked Henry Ford into using the Zenith designed for the model A in order to get the 40 HP during the engine development but is was only used on the early 4-cylinder models. All of the Ford ones had the GAV on the side but the B carbs has a more rectangular bowl shape and the larger venturi bore.
Old 09-17-2021, 09:41 PM   #3
Gary WA
Gary WA's Avatar
Not model T!! A yes more pics would help
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 09-18-2021, 05:54 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Hi DJeffrey. That's a nice looking 190A Victoria Leather-Back you have. I notice that you are not a member of the International Victoria Association. I highly recommend that you join the Association by contacting President Bill Cilker. His email is [email protected]
For the Association, I keep a record of surviving Victorias. So far I have over 600 190As on file, but not yours. Does your car have a Murray body number on a firewall tag? Email me at [email protected] if you would like to have your car in the record. By the way, if your car is missing its body number, I can reserve one for you that fits the features of your car, but you need to join the Association for this benefit. The Association also has a newsletter, The Bustle by Tom Endy.
Bob Bidonde
Old 09-18-2021, 11:38 AM   #5
DJeffrey
DJeffrey's Avatar
Hi Gary, I hope you can help. Here are more pictures of the core. Thanks.
Old 09-18-2021, 12:23 PM   #6
redmodelt
redmodelt's Avatar
It has an air balance tube, so would be industrial or farm. Off something like a Gleaner combine, maybe. With the air balance tube would have used with an air filter, more than likely oil filled type.
