Old 09-13-2021, 01:40 PM   #1
HenryCarl
Default '35 Ford Standard Trunk Seals
Drake suggested I contact both the EFV8 and FordBarn. FordBarn has always been terrific.
Attached is a screen shot of the trunk seals Drake sells. But no installation info. My car is original and the lower seal (the body not the lid) is missing. But the lid seal has hardened. Any help on which seal goes where, and do I cover the drains on the body with the seal? Thank you.
File Type: jpg Screen Shot 2021-09-13 at 1.35.47 PM.jpg (10.2 KB, 1 views)
HenryCarl is offline   Reply With Quote
Old 09-13-2021, 05:32 PM   #2
Don Rogers
Don Rogers's Avatar
Default Re: '35 Ford Standard Trunk Seals
The wider seal 1" wide by 130" long goes on the lid (48-725446) and the narrow seal 3/4" by 130" long goes on the body opening (48-725444).
Don Rogers is offline   Reply With Quote
Old 09-14-2021, 08:40 AM   #3
HenryCarl
I always know you have the answer. Thank you x 130.
Old 09-14-2021, 09:43 PM   #4
HenryCarl
I feel like Columbo. One more thing...Don, is the u slot face down on the metal for the body seal, and the lid seal... face up against the metal or down? OK. Another one more thing. Do I cover the drain holes on the body seam...Thanks.
Old 09-18-2021, 10:13 PM   #5
TagMan
Back up to Don Rogers
TagMan is offline   Reply With Quote
Old 09-19-2021, 10:39 AM   #6
Willit Stop
Willit Stop's Avatar
I believe what Henry is asking is will the U shaped grooves face each other once installed.
Willit Stop is offline   Reply With Quote
Old 09-19-2021, 11:02 AM   #7
Don Rogers
Don Rogers's Avatar
Jim, The hollow side goes into the groove so the domed part is facing out.
Old 09-24-2021, 07:14 AM   #8
ford nut
ford nut's Avatar
i've had this same question posted for awhile, no replies. no answer yet on how to deal with it around the two drain holes. anybody? pictures are always the best. . .
ford nut is offline   Reply With Quote
Old 09-24-2021, 03:26 PM   #9
325w
My guess is if water got under the U shaped seal it could run down to the drains.
325w is offline   Reply With Quote
Old 09-24-2021, 07:38 PM   #10
rich b
rich b's Avatar
rich b is offline   Reply With Quote
Old 09-24-2021, 07:43 PM   #11
rich b
rich b's Avatar
Been already answered; but here's a picture I saved when I got the seals.
Old 09-24-2021, 08:16 PM   #12
ford nut
ford nut's Avatar
Originally Posted by rich b View Post
i don't know what this **** means. i'm sorry and i'm not being rude,
Old 09-24-2021, 08:28 PM   #13
ford nut
ford nut's Avatar
i guess i wasn't in on that, my seals came from vintuque, and that might be part of the problem. there is no domed top to them. and bending them around corners makes them bunch-up and wrinkle. if the water is expected to get under the rubber and find it's way to the outlets, i can see why so many gutters are in such bad shape. do they get glued in, or is it just a friction fit? only 1/6" per leg to put glue on, so i can't see that being the plan from ford, but who knows.
Old 09-25-2021, 03:06 PM   #14
rich b
rich b's Avatar
I started the post and then couldn't find the picture, so I deleted the text. The when I found the picture; I was going to edit the post; but it seemed to have disappeared so I started a new one and of course the initial post showed up.
The trunk seal I have fits snuggly in the groove and has stayed in place without glue for a few years now. The lid seal fits snug; but needs glue to stay there.
I stopped it at the drain holes on each side as someone on here posted; but then I put a piece between the holes as I had so much left.
I don't know what brand seals I have for sure; thinking Drake.
Thread Tools
Display Modes
