Old 09-16-2021, 10:38 AM   #1
Fred A
Fred A's Avatar
Default '40 Wider Wheels?
I have 4.5" wheels from my '40 station wagon. Some seek '40 wheels and expect to find the squared profile rims. My 4.5"s are slopers and innies around the lugs.Could they still be '40? Original looking green paint is not pinstriped. Thanks: Fred A
Fred A is offline   Reply With Quote
Old 09-16-2021, 10:45 AM   #2
Kube
Kube's Avatar
Default Re: '40 Wider Wheels?
Sloped is later Fred, 1942+
Old 09-16-2021, 01:27 PM   #3
Fred A
Fred A's Avatar
Thanks Kube, guess I'll have to dig into the Service Bulletins to get more of the picture. Would have been cool on my coupe, did I say cool? It's almost a set with these on the front for 650-16s tires and the '41 Merc 16X5" wheels on the rear with whatever tires, looking so much alike. One disappointing outcome is to plan too far ahead and have the "ideal" tires rub on the wells. I should compare the offsets. Nice to have so much Ford information available, but often overlook esthetic differences like innie and sloper. Any info on when Ford wheels went from innie to outie? Part of the same quest, you see.
Thanks: Fred A
Old 09-16-2021, 01:36 PM   #4
cas3
Ford pickup's were innie's to 66, cars to 49
Old 09-16-2021, 02:56 PM   #5
Fred A
Fred A's Avatar
The part about any innies as late as '66 put a wrinkle in my brow. This place is looking like a wheel factory and lucky if I can recall the source. Most wheels in "stock" are used as rollers which is an unreliable nemonic device. I'm limiting my self to consider 16" wheels on a 5.5" lug center. Sources can be a fooler to me. Profoundly the 16,5" wheels are great for parking in the mud. Seems that 15" wheels swept the world of Fords beginning with the '42 Merc. By '57 were're rolling on 14's. What a ride! Took a look at my set of outie 16X5"wide, 5 on 5.5 pickup wheels finding them all FoMoCo which is barely worth knowing. And, No, I've not been drinking..Yet. Thanks for the response: Fred A
Old 09-16-2021, 04:32 PM   #6
Lanny
Lanny's Avatar
Here is a picture of a '40-'41 Ford car wheel and a 1946 Ford car wheel.
Back in the late 50's as dirt track racers, we would avoid running the '40-'41
16" wheels, as they are flat around the lug holes and the metal
would crack right there
You can see by the picture of the 1946 Ford car wheel. that the metal
is volcanoed out right around each lug hole and were much stronger
in that area
click on pictures to Enlarge
My Dear, I love to see your hair blowing in the wind....
Ok ok, stop crying, I'll chase after it & get it back for you.
Lanny is offline   Reply With Quote
Old 09-16-2021, 05:37 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Hey Fred ....Kube, Cas and Lanny have all given you some top-notch information. And I see that you mentioned that you have a pair of '41 Merc, 16" X 5"-wide wheels ....THE Holy Grail of old Ford wheels. I guess I'm having a hard time figuring what your question really is. I'm assuming that you want to stay with 16" Ford wheels, able to be fit with the early caps (inboard nubbies). I'm wondering if you're looking for a wheel WIDER than the 5" '41s? Do you think that any of the widths we've discussed here is too narrow for a tire like a 7.50 X 16, or a 7.50 R16?
If so, there is no reason that you can't run 7.50s on a '42-'48 4-1/2" wide automobile wheel like we have. The pictures below show an Excelsior Stall Sport Radial (7.50 R16) mounted on said 4-1/2" X 16" Ford wheel, and on a '36 3-window coupe. They run great, and tubeless to boot. Excelsior recommends a 4"-6" wide wheel for that tire. We have Excelsior 5.50 R16s on '40-'41 Ford 4"-wide wheels on front. Any of this help, or am I just confusing matters? DD
Click Links Below
T5 W/TORQUE TUBE
Old 09-16-2021, 06:01 PM   #8
cas3
That's a fine lookin coupe there !
Old 09-16-2021, 07:05 PM   #9
Fred A
Fred A's Avatar
I started with a Kube kind of question about 650s on a 4.5" wheel with a chance that Ford produced it as early as '40 for use by station wagons and commercials. I lost focus on the rear wheel knowing well that they were '41merc at 5" width of which I hoard seven of them and they also are innies. They match well from the outside. In the FoMoCo era, the 16" seems to be an option to the 15s", with 5.5"pattern, standard on commercials, both being outies and 5" wide. The F1 and F100 guys bring a few of these to the local swaps. The descriptions can get pretty involved with factory specs ranging among 16"s from 3.5" to 5" with the same lug pattern and descriptions vary. There is also the element of striping on later passenger wheels. Following? Big and littles don't suit my car or me. Perhaps using the Merc wheels would be a wasteful mismatch. As you may see the very subject is potentially confusing. Thanks for the great comments: Fred A
Old 09-16-2021, 11:15 PM   #10
cas3
Fred, I am confused now, if you are not trying for the " big & little" thing, then why are you not happy with the wheels you have? as we have seen, 40, square drop center, 4", 42 and up, sloped drop center, 4 1/2", pickup wheels are usually 5", and noticeably heavier when you lift one. A larger tire than the stock 600 will work on any of the choices
Old 09-17-2021, 02:07 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
That is Heard's (Heard Saxon) little coupe.....He will appreciate that! It looks a bit better here with hood.
Click Links Below
T5 W/TORQUE TUBE
Old 09-19-2021, 12:03 AM   #12
Fred A
Fred A's Avatar
cas3: Sounds simple if you say it quickly. Old narrow Ford/Merc wheels/tires look fine in the 75+ year old Service Bulletins but often there are surprises looking in the current catalogues and find some wheel width numbers based on wider wheel expectations. I hope to not be limited to bias tires. I've had two expensive tire failures. I will reserve selection after finding some of the vintage tires offered are already old. Big/little looks like a stink beatle to me. Big if I need the diameter. Little might be underrated on max weight alone. I know this thread is played out but the confusion needed a reply. Good Luck: Fred A
Old 09-19-2021, 12:22 AM   #13
Tinker
Tinker's Avatar
Big/little aside. I ordered "tall" tires for my f150. Didn't need to change the rim width. Not cheap though.
Well if you go the otherway they will cost you also too...
File Type: jpg Screen Shot 2021-09-19 at 12.24.55 AM.jpg (22.3 KB, 9 views)
Old 09-19-2021, 12:30 AM   #14
Tinker
Tinker's Avatar
I run 7.00 and 6 fronts on my stock rims with bia and tubes. Woe is me.
