Old 09-17-2021, 03:08 PM   #21
corvette8n
corvette8n's Avatar
Default Re: Vintage battery kill switch?
Originally Posted by 52flthed View Post
Yes I agree about the CH switches but I think they're mounted in a remote location away from the battery is that right? I was looking for something that switches near the battery. I had a little fire with an engine compartment light last year. Since then Ive had the whole truck re-wired as there were other symptoms of bad grounds and such with the lights. So being extra cautious here and thinking about disconnecting the battery as built in feature doesn't sound like a bad idea. Thanks for the ideas so far.
My CH switch is mounted thru the firewall, so I just reach under the dash near the glovebox and turn it off from inside the car. I had to do that once when I wired a relay wrong and smoked the supply wire.
Old 09-18-2021, 10:40 PM   #22
Tinker
Tinker's Avatar
I leave a cable slightly loose and pull it off battery when not using. I also forget to do so and my vehicles doesn't drain the battery with a amp leak/short.
While it's off put a amp meter between the battery and either disconnected lead. There should be no reading less you have a electronic clock or a short.
Never a bad idea to have a disconnect for many reasons though.
Old 09-20-2021, 08:07 AM   #23
glennpm
glennpm's Avatar
This is one of the types I use:
https://www.amazon.com/knife-battery...ery+disconnect
Old 09-21-2021, 01:55 PM   #24
Roger/Sacramento
Roger/Sacramento's Avatar
I have an OPTIMA battery under the passenger seat and mounted a master switch (CH type) mounted on the seat frame behind the stick shifter.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 09-22-2021, 04:57 PM   #25
Pete
Pete's Avatar
If you want the maximum safety with a total system cut off switch, it should be mounted as close to the battery as possible and in the GROUND strap.
NEVER IN THE HOT LEAD.
With other systems the main cable is left hot with the switch off.
There are several other manufacturers of heavy duty switches similar to the Cole Hersee one. They can be mounted in the center cross member just ahead of the driver seat with the shaft up through the floor for easy access.
Done right the floor mat will cover the handle yet it will still be easy to access.
