04-27-2023, 05:55 PM | #1 |
Engine splash pan repair dimension needed
Hi all,
Friend of mine wanted to fix the original engine splash pans on his A.....tabs are broke and / or missing. I need a dimension on one of them. See pic attached below if someone can get me the center to center dimension that would be a huge help. I have all Model T stuff so i dont know what it should be and unfortunately the A is not easily accessible at this point. Thanks in advance. |
04-27-2023, 07:21 PM | #2 | |
Re: Engine splash pan repair dimension needed
04-28-2023, 06:18 AM | #3 |
Maybe he needs the measurements from the block rails to the frame
04-28-2023, 11:43 AM | #4 |
Chad, I think you are picturing the passenger side pan (no cut-out for steering/light fitment), mine is approx.. 171/2".
Driver side with cut-out area is approx. 15". If you are fabricating tabs, might be an idea to have an oblong hole cut in each tab to allow some movement if not lining up exactly.. kb |
04-28-2023, 12:14 PM | #5 | |
04-28-2023, 12:15 PM | #6 |
04-28-2023, 02:26 PM | #7 | |||
04-28-2023, 02:43 PM | #8 |
It might be best to measure directly from the application you are fixing them for.
04-28-2023, 02:45 PM | #9 |
Thanks Y-Block.. Yes, I do stand corrected.! Cut-out is for exhaust clearance.. kb
04-28-2023, 08:07 PM | #10 |
@Y-Blockhead, thank you very much for the correction and information. Very much appreciated.
04-28-2023, 08:09 PM | #11 |
04-28-2023, 09:45 PM | #12 |
I missed that.
