08-16-2020, 07:58 PM | #61 |
Re: Electrical Issue advice
rockfla, I have just checked the underside of my spare FUN PROJECTS regulator and it is exactly the same as your regulator. The underside of an original cut out is different. So you have a regulator which is possibly still OK and you wont know until you have a working ammeter. Another way to test your charging is to connect a voltmeter or multimeter set on around the 20 volt DC scale and connect between the ground and either of the regulator terminals and with some revs up on the engine you should have around 7.2 to 7.5 volts. If it is under 7 volts then it is not charging. See how you go. Regards, Kevin.
08-16-2020, 08:05 PM | #62 |
The Fun Projects regulators have a slit or cut in the cover each side under each terminal. Original cut outs also have a special hex head terminal bolt and not a slotted screw like on the regulator type. Regards, Kevin.
08-17-2020, 07:28 PM | #63 |
So, today when I got home I hooked my meter up at the generator cutout and here is what I did. I connected the ground lead to the screw/wire at the base of the cutout. I connected the red lead to the “A” screw/wire of the cutout. Picture one is hooked up no power not running. Pictures 2 and 3 are running and about the highest and lowest readings on my meter. I also spoke with Fun Projects today and can send my cutout back for testing and or repair if needed.
08-17-2020, 07:56 PM | #64 |
Not sure what you are reading. Your meter appears to be on AC mode with
the selector on 10amp and the red lead plugged into the milliamp jack. |
08-17-2020, 08:20 PM | #65 |
Your meter is not set correctly. Switch has to be set on V for volts. Has to be DC volts NOT AC volts. The red test lead has to be in the volts ohms hole. You will never get a correct reading with it set the way you have it now. Regards, Kevin.
08-17-2020, 08:31 PM | #66 |
08-17-2020, 08:33 PM | #67 |
Doesn’t the ammeter measure amps? So why would I need to measure volts coming out of the generator?? I thought somewhere some one said I should be reading around 7-7.5 amps from the generator
08-17-2020, 08:48 PM | #68 |
Should be reading around 7-7.5 Volts. If you were trying to read amps
the meter needs to be in series between the generator output and the wire going to the battery. |
08-17-2020, 08:56 PM | #69 |
Okay, I’m done. I’m ordering the correct generator from Mike tomorrow and sending the cutout back to Fun Projects, that way there is NO doubt. Now I’m down to a stuck ammeter? I’ll pull that tomorrow and investigate. Thanks for all y’all’s attempts to help
08-17-2020, 09:23 PM | #70 |
I am trying to get you to read VOLTS. I know the meter is autoranging but the switch needs to be set to volts. The red lead has to be in the VOLTS & OHMS socket. Dont give up on this now because there is a possibility that the generator and regulator is still OK. Forget about amps at this stage. We are looking for above 7 volts out of the generator with the engine revved a bit. Generators do not charge at engine idle speed. I will be disappointed if you dont follow along here, Otherwise I will have wasted my time. Regards, Kevin.
08-18-2020, 06:36 AM | #71 | |
I will try to slide by this morning and run a quick voltage test. I assume you probe the two wires coming out of the generator? I will try and post pictures and should be around lunch time today EST (USA). I see we are 14 hours difference mate!!! Timing doesn't work for either of our schedules |
08-18-2020, 07:49 AM | #72 | |
08-18-2020, 08:10 AM | #73 |
To add to Kevin’s instructions be sure it’s not hooked to a battery charger during the check.
08-18-2020, 05:41 PM | #74 |
SO, I have two VO meters and put both on the car, one I got a 0.5 volt reading as a high with the car at an increased throttle. My other read a 0.7 then switched to.694 as a high reading increased throttle! So I take that as the generator is fried?
08-18-2020, 07:06 PM | #75 |
Assuming you have tested as per instructions previously posted then your meter readings are showing that the generator or regulator or both are at fault. I guess you will have to get some professional help on this by taking the generator to your local auto electrical shop and get him to run it up on his test bench. Make sure you tell him this is a POSITIVE ground unit, especially the regulator as it is electronic. Regards, Kevin.
08-18-2020, 07:13 PM | #76 | |
Pulling the ammeter tomorrow and getting it off for repair as well!! Thanks again for yours and everyone else’s help and advice, my more trusted meter that read .694 volts I took over to the battery on my 39 Merc and it read 6.32v so I know that meter is “on”!!!! |
