07-26-2020, 01:51 PM | #21 |
Re: Filling a brakes system
Gravity bleeding will work well; if the master cyl. is firewall mounted, not so much for under the floor units.
I've messed around with pressure bleeders and using the Mityvac over the years along with the "helper"... best thing I've found are Speedbleeders. Put a set on my '40 and it was the easiest and least messy by far. But YMMV |
07-26-2020, 03:20 PM | #22 |
I have both a Mityvac vacuum unit and a Motive Products pressure bleeder. The pressure bleeder works better than the vacuum bleeder. My Mityvac sucks air around the brake valve no matter what I do so I always see air bubbles. The pressure bleeder pushes the fluid out so the only bubbles you see is the air in the brake line making it easy to tell when the line is free of air. In addition the pressure bleeder doesn't need a air source so you don't need power and an air hose. The purchase price of both units was very sim and you can even build your of pressure bleeder using a 1 gallon sprayer if your handy.
07-27-2020, 05:47 AM | #23 |
I had a "Mity-Vac" and it never worked for me. I now use "Speed-Bleeders" and am another enthusiastic supporter.
07-27-2020, 10:21 AM | #24 |
I know this doesn't answer the OP's question, but recently a 30 year old friend helped me install a rear axle assembly in my F350 because he has a lift. Well when it came time to bleed the rear brakes he grabs this thing that looked like an anti theft 'club' that fit between the steering wheel and brake pedal. Next he hooks an air hose to a fitting on it and a jumper to the battery. After that he pulls out a little wireless key fob switch which activates an air switch solenoid. It was sort of like a wife that never gets tired of stepping on and off the pedal. All done in about a minute.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
07-27-2020, 11:13 AM | #25 | |
The diaphragm pressure bleeders are the correct (and best) tool for brake bleeding, keeping air separate from the fluid. |
07-28-2020, 07:10 PM | #26 |
