Old 04-11-2020, 04:41 PM   #1
Dougs 28
Dougs 28's Avatar
Default Starter question:
Went to start the A today and the starter wouldn’t engage, so I took the starter off and noticed that the spring on the bendix drive was broken. My question is can I replace the spring or do I have to replace the entire bendix drive?
Thanks, Doug
Dougs 28 is offline   Reply With Quote
Old 04-11-2020, 05:28 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Starter question:
If the Bendix isn't obviously damaged you should be able to replace just the spring . I've done it before .
Old 04-11-2020, 06:35 PM   #3
Sunnybrook Farm
Sunnybrook Farm's Avatar
Replace it, you might find an old one somewhere as they use the same parts on cars for years and tractors. The guy who rebuilds them for me used a bendix off of a tractor and I couldn't see any difference. Just make sure no broken parts went down in the bell housing.
Sunnybrook Farm is offline   Reply With Quote
Old 04-11-2020, 07:42 PM   #4
Dougs 28
Dougs 28's Avatar
https://www.fordbarn.com/forum/attac...1&d=1586652018
File Type: jpeg EFE852D2-1B90-4281-92CF-1A994B3952AA.jpeg (108.9 KB, 72 views)
Old 04-11-2020, 07:45 PM   #5
David R.
Common problem, replace spring. Keep a spare. Make sure bolts aren’t bent. Always retard spark to start. Leading cause of starter damage is kick back.
David R. is offline   Reply With Quote
Old 04-11-2020, 10:06 PM   #6
Redbird
Redbird's Avatar
Order new keepers for the bolt heads. Stops the bolts from backing out down the road. I had it happen to me.
Redbird is offline   Reply With Quote
Old 04-12-2020, 06:24 AM   #7
kenparker
kenparker's Avatar
I would order new spring, two bolts and the two special spring lockdown washers. The two bolts just in case the threads in your originals are damaged. The bolts ans washers come in two sizes, (5/16" and 3/8"). Make sure you get the correct size that matches your bendix.
kenparker is offline   Reply With Quote
