Old 09-04-2017, 11:05 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Another back up light question-1950 Ford
One a 50' Crestliner, the back up lights come on only when the headlights are on. Is the power side of the back up light switch connected to the wrong place, or was this standard wiring at the time.??
Thanks for all the other answers on the back up lights!!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 09-04-2017, 11:45 PM   #2
Paul Bennett
Default Re: Another back up light question-1950 Ford
You would not want the reverse/backup lights to be on if the car were parked engine off headlights off - transmission left in reverse.
Things can be wired anyway you envision. What conditions do you want the backup lights to come on? Reverse w/parking and or headlights on? Engine running? Key turned to run or accessories?
Once you establish what you want, power the backup switch from there (such as coil position of ignition switch.)
Paul Bennett is offline   Reply With Quote
Old 09-05-2017, 06:59 AM   #3
Cecil/WV
Cecil/WV's Avatar
My '50 is wired to the ign switch. '55 Fords were wire to the headlight switch.
Cecil/WV is offline   Reply With Quote
Old 09-05-2017, 07:51 AM   #4
Frank Miller
Frank Miller's Avatar
You're car is wired factory correct. It was not until later that people figured out that backup lights was a good warning for others around the car.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 09-05-2017, 08:04 AM   #5
Pat/Ohio
Pat/Ohio's Avatar
I believe the backup lights are supposed to wired to the taillight post on the light switch. That's what is indicated on the instructions sheet that came with my backup light kit. Pat
Pat/Ohio is offline   Reply With Quote
Old 09-13-2017, 08:15 PM   #6
Pat's 52
Pat's 52's Avatar
The back up lights only worked when the car lights were on.
Pat's 52 is offline   Reply With Quote
