05-08-2011, 07:57 PM | #1 |
1954 Mercury duals
I have a 1954 Mercury, what is the least expensive way to install duals and where can the parts be purchased?? It is a straight drive car. Thanks in advance
05-08-2011, 11:34 PM | #2 |
Re: 1954 Mercury duals
If it is a Y-block and you currently have single exhaust, you will need to get dual exhaust manifolds. I think the Merc Y-block was a 256 that year. You might be able to get exhaust manifolds from a Ford 235, 272, 292 or 312. Sometimes they are for sale on e-bay. I have a pair sandblasted and painted with Hi-temp here but I wont part with em. Sorry. You can buy a complete exhaust system from Concours Parts that includes everthing from exhaust dump to tailpipe if you are willing to take the mufflers that come with the kit. You will also need to buy the muffler frame bracket for the driver side frame rail since you only have one on the passenger side now. Concours sells them also. In my opinion those kits are not the greatest. If I were to redo mine again, I would let a local muffler shop make up the pipes and let you choose the mufflers you wanted
05-09-2011, 07:16 AM | #3 |
I bought a complete exhaust system from Waldron Exhaust. They advertise in Old Cars Weekly. The parts are much heavier than I expected, very good quality. I highly recomend them. I have an extra set of exhaust manifolds I would part with, PM me if interested.
05-09-2011, 10:31 AM | #4 |
You might check around your area for a shop that does custom exhaust work. I had mine done locally (michigan) - manifolds to tailpipe for about $200, included all parts, brackets, hangers, (EXCEPT mufflers) and labor.
That way you can buy good, better or best mufflers depending on your budget and the shop will fit them to the car. I did Porter steelpacks on my '56 Fairlane 292, they weren't 'cheap' at $60 each but sound great. But yes as said earlier, you'll need a set of dual exhaust manifolds too. Ron |
05-09-2011, 03:30 PM | #5 |
if you want to do it on the cheap you can cap the front of the manifold on the pass,side.then get a duel manifold for the drivers side.then you only have to deal with one side.
05-09-2011, 09:16 PM | #6 |
The other option is using both stock manifolds. Shut off the right side with a plate. On the left side, make up a pipe that attaches to the stock manifold and loops around to the back. |
05-10-2011, 01:52 PM | #7 |
Paul hit the nail on the head 1954 is all by itself,the clutch linkage will not clear later Y-block manifolds.One of our 1952-56 Ford group members on the HAMB used the Red's Headers on His '54 the fit was great and He loves them.Contact them at 1-(760)343-2590 for info, they have been around almost 60 years.
05-10-2011, 03:54 PM | #8 |
i used the reds headers on my 55 merc wagon and had to turn the left side down to clear the z bar 292 motor w/ duals
