Old 02-24-2019, 06:20 PM   #1
Arty
Default 31 Coupe Wood (Under side window)
Hi All:
Does anyone have a 1931 couple with the wood exposed? I picked up a partially finished project and I think I am missing a piece of wood that goes behind the pillar and under the side window wood. I think I can make one, just need an idea of what it should look like.
Thanks Arty
Arty is offline   Reply With Quote
Old 02-24-2019, 07:42 PM   #2
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Default Re: 31 Coupe Wood (Under side window)
Here is a picture of mine. That beveled piece held with a screw appears to be hard rubber but could probably be made from hardwood. I don't remember what it's for.
MickeyT is offline   Reply With Quote
Old 02-27-2019, 01:24 AM   #3
Drive Shaft Dave
upholstery panel nails to this.
Drive Shaft Dave is offline   Reply With Quote
Old 02-28-2019, 08:53 AM   #4
Arty
Thank you both. MickeyT - any chance I could get some rough dimensions?
Over Length?
Distance from door pillar to 1st screw?
Door pillar to second screw?
Second screw to the end of the block?
Height of face?
I think I can eyeball if needed, but if you could get some dimensions it would be greatly appreciated.
Old 02-28-2019, 05:29 PM   #5
MickeyT
I hope this helps. You are also missing a small 4" long block that goes between the bracket and the frame of the window. It's the same thickness as the window frame. That missing piece of wood is supposed to be sitting level. Not sloping downward on the left side the way mine is. It is made of rubber but it's for nailing the upholstery to so wood should be just fine. Where the screws go isn't a big deal they're just to hold the piece to the small block behind it. The tracing is full size. BTW where are you located?
Old 02-28-2019, 05:54 PM   #6
Arty
Thanks MickeyT - You went way above and beyond and I really appreciate! I am in the Chicago area and will definitely be able to make something that works now that I can see the different angles.
Can't thank you enough.
