06-07-2021, 09:25 PM | #1 |
1932 transmission prefix 18-oooooo question
I'm putting a 36LB V'8 engine in a 32 with it's what appears to be a 32 stock
V-8 transmission. The 32 clutch appears much different and the flywheel is indented . Will the 36 engine fit without any problems. This is the first 32 I ever worked on and am concerned the bell housing may not work between the 32 transmission and the 36 engine. Any input would be appreciated FrankPKNY
06-07-2021, 10:50 PM | #2 |
Re: 1932 transmission prefix 18-oooooo question
The '32 transmission case and input shaft will mate just fine with a '36 LB or non-LB or any other flathead V8 engine of the period. Ignore the '32 clutch and flywheel and use those intended for the vintage of the engine.
06-08-2021, 10:17 AM | #3 |
06-08-2021, 11:40 AM | #4 |
06-08-2021, 12:01 PM | #5 |
No, but sometimes I make good guesses.
06-08-2021, 01:19 PM | #6 |
Paul in CT He wrote the book. |
06-08-2021, 04:26 PM | #7 |
Thanks for the information. I thought it would work with a nine inch clutch set up. I love these old Fords. FrankPKNY
Thread Tools | |
Display Modes | |
