10-26-2015, 08:08 AM | #1 |
Wesenberg Coil Tester
I think Tom wesenberg had plans for a coil tester. Can someone direct me to it please. If I'm not remembering correctly I'd appreciate direction to other home built coil testers please. Thanks.
10-26-2015, 08:12 AM | #2 |
Re: Wesenberg Coil Tester
my coil tester is the car... many act up with temperature and show good on the bench
10-26-2015, 10:02 AM | #3 |
You can bet your wallet that if Tom does a bench tester it will be top shelf Becayse everything he does reaches that mark! Wayne
10-26-2015, 02:46 PM | #4 |
Here You go ! http://model-a-ford.org/technical-re...n/coil-tester/
10-27-2015, 12:00 AM | #5 |
I liked Tom Wesenberg's coil tester so well that I made my own. Like most of you say there is nothing like testing it on the car but is kind of fun to play Frankenstein with it. You could take a heat gun and warm up the coil to see if it would fail, but if you had some coil's and condenser's it would be good to sort good from bad.
10-27-2015, 08:25 AM | #6 |
10-29-2015, 03:57 AM | #7 |
Hey Tom,
Make up a few and I bet they sell like hot cakes. Dave
Dave A Jamieson Portland, ON Canada 1928 Tudor |
10-29-2015, 06:09 AM | #8 |
The surplus store where I bought the relay doesn't have any more like it, and I'm waiting for the rain to quit so I can drop my Olds gas tank to repair a leaking rusted fuel line on the tank sender. Just can't get caught up with repairs much less take on more jobs right now.
10-29-2015, 07:03 AM | #9 |
FWIW, I made one up with a relay that was laying around once just to play.
So the exact brand is likely to matter much. Might have to play with the capacitor/ resister values to get the speed you want. |
